Electrical/Engine problem i think - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2010, 12:53 AM   #1 (permalink)
B0R1CHA
b0r1cha's Avatar
Gameroom cash: $125535
View b0r1cha's Photo Gallery
Gen6 Electrical/Engine problem i think
CAR: 2008 toyota camry SE V6 30k miles 2 years old
So this happenned for the first time sunday afternoon. I was listening to music in the car for probably 15 mins at most while my key was in the first click. (car is off) then i turned it to the 2nd click to close my windows when my car's electricity went out. TOTALLY OUT. so i unplugged the negative part of the battery and put it back on (so i restarted the car basically) then it worked. Today, i had to do this in the morning, and 2 more times throughout the evening. It seems everytime i want to start my car, i would have to unplug the battery and plug it back in.
anyone know wat the problem could be?
19x8.5 +35 Axis Hiro for sale
b0r1cha is offline   Reply With Quote
Old 02-09-2010, 02:03 AM   #2 (permalink)
View sitandthink's Photo Gallery
get a new battery... problem solved...
sitandthink is offline   Reply With Quote
Old 02-09-2010, 02:21 AM   #3 (permalink)
B0R1CHA
b0r1cha's Avatar
its not the battery cuz when i unplug the battery and plug it back in, it works fine. and happens out of random too.
Old 02-09-2010, 02:31 AM   #4 (permalink)
it happened to me before... If you don't trust me just go to local autozone ask them to run a check on your battery... speaking generally 30k is the time to get a new battery
Old 02-09-2010, 03:59 AM   #5 (permalink)
B0R1CHA
b0r1cha's Avatar
hmm but theres a thing on the battery that shows the color green when the battery is still good and its showing green. is that unreliable?
also, if the battery was bad, simpling unpluging the battery and plugging it back in wont make it work all of a sudden will it? cuz if the battery is bad resulting in me not being able to start my car, unless i get my battery jumped by something, wouldnt it still not have enough juice even when i unplug the battery and plug it back?
Old 02-09-2010, 04:41 AM   #6 (permalink)
sxe-10's Avatar
Gameroom cash: $133154
View sxe-10's Photo Gallery
do you still have your warranty with toyota? Or maybe extended(not sure what it covers), but if not, I'd prob get the battery checked just to make sure before you have toyota charge you to have the car diagnosed
btw can the fuses, maybe wiring being loose or blown cause this? Im not too sure, not a hardcore tech or electrical guy but would check what I can first to the best of my knowledge before paying toyota or a shop do it
sxe-10 is offline   Reply With Quote
Old 02-09-2010, 05:14 AM   #7 (permalink)
B0R1CHA
b0r1cha's Avatar
yeah my warrenty is probably void because of all my mods but this started happenning after i got my car back from the dealership after getting my airbag fixed.... i wonder if i can put that on them and have them diagnose it for free. knowing the stearlership, they'll proably diagnose it and blame it on something else even if it was thier fault... bastards
i'll try getting the battery tested.
Old 02-09-2010, 07:49 AM   #8 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
That does sound very strange. 30K should still under warranty, let the dealer check it.
workerant is offline   Reply With Quote
Old 02-09-2010, 03:36 PM   #9 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Taking a stab at it...alternator?
CarDomain
Old 02-09-2010, 04:16 PM   #10 (permalink)
B0R1CHA
b0r1cha's Avatar
i dont think it is cause like i stated earlier, when i unplug the battery and plug it back in, it works fine. Thats why its soo weird....
Old 02-09-2010, 04:35 PM   #11 (permalink)
trehouse's Avatar
View trehouse's Photo Gallery
how about connections at the battery? are they very tight and solid?
have you previously disconnected the batt for anything before this?
sounds like a real pain to have to do this to start the car. before you disconnect and reconnect is the car dead, lights very dim, etc? or is everything like it should be OK?
trehouse is offline   Reply With Quote
Old 02-09-2010, 04:45 PM   #12 (permalink)
B0R1CHA
b0r1cha's Avatar
i did recently take the connections off. i just tightened them down right now. the connection seeemed to be good enough but i remember in my accord, i had the connecton loose on the battery and sometime when i started the car i guess the power sucked fro mthe battery caused the ring to pop off the connection so i would have to connect it back.
but this time, the rings are on the connection. i would have to take the ring off and put it back on. as if ur restarting a phone or mp3 player etc. after i "restartd" the car when i was turning the ignition on, it sounded weaker. i took the car for a drive to see if there was any power loss but everything seems fine. just starting the car is the problem. i'll be leavking my house in about 45min to an hour so hopefully it'll be working fine now.... after tightening the connection down.
Old 02-09-2010, 04:55 PM   #13 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
Here's an idea: Go to Wal-Mart and pick up a battery & install it in your car. If it solves the problem, then you know what the problem was. If it doesn't solve the problem, just take it out, put your old one back in, and return the battery to Wal-Mart. This way you can find out if the battery is the problem and you won't have to spend a penny. Even if it does solve the problem and you don't want a Wal-Mart battery, you can still return it and go buy whatever battery you want. It's Wal-Mart so they will happily give you a refund without asking any questions. If they do ask just tell them you accidentally bought the wrong type of battery, lol.
ScrooYoo is offline   Reply With Quote
Old 02-09-2010, 05:12 PM   #14 (permalink)
Gameroom cash: $240090
View The7's Photo Gallery
Do you have an voltmeter (DMM)?
If so, try to measure the battery voltage :
a) when it is at OFF
b) when the engine is not running at ON position;
c) when the engine is not running and the radio is turned ON;
d) when you could not start the engine;
e) when you could not close or open the electric window;
f) when the engine is running at idle and at about 2000rpm.
These volt readings could give better insign of your car.
The7 is offline   Reply With Quote
Old 02-09-2010, 05:45 PM   #15 (permalink)
That is what I'm trying to tell him... He just makes problem complicate...
Go to autozone they check your battery for free, it does not hurt you...If you still in guarantee and if the problem not from the battery just ask the dealer to fix that... They cannot decline your guarantee unless the problem come from your set up... For example you put a sub on and that kill the rear speakers then they would decline your guarantee just for the rear speaker not your entire car guarantee...
99% sure it would be the battery problem since you said you leaves the radio on... which mean your habit is listen to radio without turn the engine on these would mean the radio sucking the juice from the battery often => lower battery life/power.
