Best Choice in Oil Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2010, 04:52 PM   #1 (permalink)
View BuckeyeGuy's Photo Gallery
Hi All. I'm getting ready to do my first oil change in my '10 Camry LE and I'm trying to figure out what filter to go with. I called the dealer on a non related issue and started talking to the parts guys and of course they recommended I use the Toyota filter. Guy said that he's heard issues with engine knock with folks that have tried other filters. The only positive I've heard in terms of a filter is a Pure One. I plan on using Mobil 1 Syn, and thought about using their filters, but I've not heard too much about them. I've seen much written that's negative about Fram, so I guess I'll stay away from that. Anyone else have a suggestion? Thanks.
2010 Camry LE w/ EX and QA
Build Date: 12/09
Covercraft Full Mask/Husky Trunk Liner/
Toyota Mud Flaps/iPhone 3GS Bluetooth
BuckeyeGuy is offline   Reply With Quote
Old 02-12-2010, 04:56 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Buy oem in bulk on ebay. done.
CarDomain
Old 02-12-2010, 05:01 PM   #3 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
OEM or Pure One. And get an oil filter wrench, it'll make the process easier.
toyotaholic is offline   Reply With Quote
Old 02-12-2010, 05:28 PM   #4 (permalink)
09SILVASE's Avatar
View 09SILVASE's Photo Gallery
I got a 10 pack of OEM filters from ebay for $30. Pretty good deal.
09 Silver Camry SE 4 cylinder
09SILVASE is offline   Reply With Quote
Old 02-12-2010, 08:34 PM   #5 (permalink)
webjones's Avatar
View webjones's Photo Gallery
This is an interesting read.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
I personally like the Purolator Pure One.
2003 Camry LE - Phantom Grey Pearl
2009 Camry LE - Magnetic Grey Pearl
2006 Jeep Commander - Dark Khaki
webjones is offline   Reply With Quote
Old 02-13-2010, 03:29 AM   #6 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
TRD oil filter
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is online now   Reply With Quote
Old 02-13-2010, 01:11 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Engine knock happens even on new Toyota/Lexus 3.5L on the dealer lot. Well, that's actually "piston slap" because of loose production tolerances. Cost cutting I guess.
Purolator's PureOne is an excellent oil filter. I don't know if the PureOne line is always using the excellent Micronic media made in the US. I know PremiumPlus sometimes has imported filters that Purolator doesn't make.
Your 2.5L 2AR-FE engine uses a European style eco-friendly filter element. So I'd recommend that you buy from OEM (dealer or online bulk as suggested) unless the PureOne box at your local parts store has one made of the Micronic media made in the US. The last time I checked they were still only PremiumPlus using imported filters. That might have changed.
I'd use PureOne over Mobil-1. No Frams. If you can't get a PureOne with Micronic media, then stick with OEM. Keep all your receipts for warranty purposes.
Old 02-14-2010, 02:46 AM   #8 (permalink)
View coolbeans's Photo Gallery
hmmmm. So, OEM over Mobil 1??
coolbeans is offline   Reply With Quote
Old 02-14-2010, 01:40 PM   #9 (permalink)
View blueridge's Photo Gallery
I use a K&N P1003 filter with German Castrol 0W-30 oil. Love this set up and the slight increase in MPG. The K&N filter is very easy to get off with the 1" nut on it.
blueridge is offline   Reply With Quote
Old 02-14-2010, 01:55 PM   #10 (permalink)
SSBN's Avatar
View SSBN's Photo Gallery
Mobil 1 is a good filter. Check out www.bobistheoilguy.com . It has great info on oils, filters etc.
'08 XLE V6 Magnetic Gray, Nav, leather, Heated seats, VSC/Trac, Smart key, Remote start,K&N,35%front/5% rear tint
SSBN is offline   Reply With Quote
Old 02-14-2010, 02:13 PM   #11 (permalink)
heartdisease's Avatar
Gameroom cash: $106470
View heartdisease's Photo Gallery
I use a mobil one. I might go back to stock after I run through my stash I don't know yet. I will say that the mobil filter is shorter than the oem. This makes removing it from my Camry much more difficult. I have a filter wrench from wally world and it will not remove it. It will install it, I just do a quarter to half turn past hand snug. I just had a night mare yesterday with it. I even did the old screwdriver though it and couldn't get enough room to get good leverage. I finally bought the specfic Toyota wrench and even that wouldn't remove it. I ended up getting one of these http://www.lislecorp.com/tool_detail.cfm?detail=1224
Any way back to the question at hand. I belive in Mobil oil and filters. I have used them exclusively for about 750k miles on several vehicles. They claim to filter to one micron. I don't know about the other filters but I know that if the regular parts store filters did they would shure brag about it. Fram had a big campaign to tell you that they dipped thier filters in grippy goop, I am sure they would mention one micron if they did filter that fine.
heartdisease is online now   Reply With Quote
Old 02-14-2010, 02:17 PM   #12 (permalink)
Mobil-1 is a very high efficiency filter. Didn't see it in Pep Boys but Amazon sells packs of 2 for about $37 (~$18.5 each)! Personally, I'd change out the wimpy sized filter more often then leaving an expensive one in there for the long haul.
I only saw PremiumPlus standard line of Purolator there. Made in the US. Looks OK. But you might not get a price advantage over the OEM bulk with that.
So if you find PureOne or Mobil-1 those would be fine. Then it's lower price of either the Premium Plus or OEM.
Old 02-14-2010, 02:20 PM   #13 (permalink)
Yes, Mobil-1 is great.
BTW, the OP's 2010's gone eco-friendly with filter element insert. No canister.
Old 02-14-2010, 02:35 PM   #14 (permalink)
BTW, what engine does OP have?
Just making sure.
Old 02-14-2010, 03:27 PM   #15 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Either OEM or Mobil1, I've got loads of OEM filters and have been using them for years, no problem whatsoever.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
