Driver Side Door Mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2010, 12:57 PM   #1 (permalink)
View tamina1's Photo Gallery
Hi, This past weekend someone knocked off the driver side door mirror from my 2008 Toyota Camry. The case and mirror were lying near the car on the ground. The mirror is not even cracked! Does anyone know if I can use the same piece and have it attached back to the car? If not, where can I find a blue driver side mirror. My car is metallic ribbon blue (the dark blue) and all the searches I have done so far have black mirrors. I called the dealer and they are saying $200! I think that is very expensive. Any help will be appreciated! Thanks!
tamina1 is offline   Reply With Quote
Old 02-16-2010, 01:01 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
You can try hitting up a junk yard. If you're lucky, they'll have your color. If not, you'll need to get it painted. If you dont mind getting it painted (should probably cost no more than $40-60), there is someone in the FOR SALE section of the forum that has a red color mirrored for both driver and passenger side.
CarDomain
Old 02-16-2010, 01:05 PM   #3 (permalink)
Thank you so much!
Old 02-16-2010, 01:09 PM   #4 (permalink)
must.resist.modding
bandit's Avatar
Also, I believe the mirror can be attached back on as its held by clips. If you do a search on the forums, I believe its mentioned on there and some part numbers if you decide to go the dealer route.
Here is link
Need help with driver's side mirror
Another option is eBay
CarDomain
