Problem with DDM Tuning HID Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2010, 06:37 PM   #1 (permalink)
07 Camry SE
View korva's Photo Gallery
Gen6 Problem with DDM Tuning HID Kit
Ordered and recieved a HID kit from DDM tuning. Installed them and only one headlight will turn on. Did some searching, and bought a relay harness hoping it would fix the problem. Installed that and the same problem continues. Only one headlight will turn on.
Everything is installed correctly, I have checked 10+ times just to make sure. I have switched the bulbs and ballast and no matter what I do, only one headlight will turn on.
I am quite confused. Anyone have any ideas?
Ive done a lot of searching on the internet and the only other possible solution would be for me to to disable the DRL(Daytime Running Lights). After searching I have seen that the only way to do this is to take it to the dealership and have them do it. I have a feeling my toyota dealer will not do it.
Any help is appericated, thanks.
korva is offline   Reply With Quote
Old 02-21-2010, 06:40 PM   #2 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
First, your dealer will do it. It is a customizable option that is available to you.
Second, if one bulb is working and the other is not, it is not a DRL problem. I know you said you checked your wiring 10+ times, check one more.
Make sure that the pos and neg hookup's on your non working bulb are connected properly to the balast. Switch the two wires around if you need to. Something on that particular side isn't hooked up properly.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 02-21-2010, 06:41 PM   #3 (permalink)
My other cars a DSM!
View BiGbodyANT's Photo Gallery
just out of curiosity which kit did you purchase. They have the budget raptor kit for like 30 and then theres the the fully digital for $50.
also try swapping out bulbs from left to right maybe its a bad bulb.
BiGbodyANT is offline   Reply With Quote
Old 02-21-2010, 06:47 PM   #4 (permalink)
D33P$3T
Gameroom cash: $241452
View nitrous3's Photo Gallery
yea I don't think the DRL's have anything to do with it like what ebumdude said. It's probably something with the wiring.
nitrous3 is offline   Reply With Quote
Old 02-21-2010, 06:55 PM   #5 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
did you switch your ballast\bulb with the other side? see if it could be defective bulb\ballast?
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 02-21-2010, 06:58 PM   #6 (permalink)
molson.david's Avatar
Gameroom cash: $293553
View molson.david's Photo Gallery
i got 2007 camry and HID kit installed.you don't have to disable DRL, not with harness.
check battery,maybe it dieing.
if you sure that both ballasts and bulbs are good,the only problem could be the harness itself. make sure ground is good and you got power on both connectors.
if so,but still,only one side works,replace wire from relay to right light (my guess,right not working) with higher AWG. do the same with wire from battery to relay.
harness wires probably 16 AWG,replace it with 12.
my left light was starting fine,but right one, only after left warms up.i replaced wires to lower impedance,on my old kit.they worked good since that.knock-knock-knock!
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 02-21-2010, 07:04 PM   #7 (permalink)
07 Camry SE
Yes, I have checked the wiring again.
I have switched the ballast and the bulbs, there is always one light not working.
I have the DDM HID Slim Ballast 55watt kit.
Old 02-21-2010, 07:28 PM   #8 (permalink)
wait just to be clear you said you switched the ballasts and the bulbs. Im talking about taking the bulb only from the non working side and putting it on the working side. Leaving the ballast where it is. You make it sound like you switched the whole setup.
Old 02-21-2010, 07:34 PM   #9 (permalink)
07 Camry SE
Yes. I have tried switching just the bulbs, switching just the ballast, and with/without the relay harness.
My battery seems fine
Old 02-21-2010, 08:01 PM   #10 (permalink)
07 Camry SE
If it matters, I have a 2007 Camry SE V6.
Old 02-21-2010, 08:03 PM   #11 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
So is it always the same side? You need to pinpoint what is wrong. Is it the bulbs or the ballast. Its not the relay because it happened before you even purchased it.
If its the driver side, swap the bulb. If the driver side is still not working, its not the bulb. Than swap the ballast. If the driver side is working but the passenger side isnt, than you found your problem.
If its the same side every time, check wiring cuz you might think you have it right but you're probably over looking something.
CarDomain
Old 02-22-2010, 11:10 AM   #12 (permalink)
Lastly plug the setup into another car. if that doesnt solve it ddm is lifetime guarantee.
Old 02-22-2010, 02:35 PM   #13 (permalink)
07 Camry SE
That I have not tried, everything else I have tried.
Should have a response by tomorrow. Going to call a friend and test it on his car.
Old 02-22-2010, 04:23 PM   #14 (permalink)
View Matm_1's Photo Gallery
Same thing happen to me but i switch the wires around and same thing happen only one headlight will turn on even tho i switch them and around and both will turn on, it was a defect on the ballats so i had to get them replaced ones that was done i had no more problems...
Matm_1 is offline   Reply With Quote
Old 09-06-2010, 11:07 AM   #15 (permalink)
Gameroom cash: $217200
View 09YotaLE's Photo Gallery
yeah the only thing i could say is try wiring it again like everyone else told u..i got a DDM tuning kit also and i had a problem with it..i got the 45w kit and one bulb went out..i didnt hear any noise coming from the ballast but i waited a few days and tried wiring it again and it worked.
Still speedin in the 2.4L
| Mods: Tints 35% Front 20% Back, 17" Rav 4 wheels, 4500k DDM Tuning HID Kit,SE grille swap, Fog Lights, 7" In-Dash Pioneer TV|| Mods to come: Lexus Es300 Fogs, Full LED Interior,H&R springs..nothing too serious.
09YotaLE is offline   Reply With Quote
