Please help: Horn toots when starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2010, 09:43 PM   #1 (permalink)
View SoldOnToyota's Photo Gallery
I have a 2005 Camry SE with 65k miles. When I engage the starter with the ignition key, the horn gives 2 short toots during ignition. I don't see any other problem related to this. It is just annoying. This happened for a short time a year ago and stopped. It started again a few months ago and has continued consistantly. Any suggestions??
SoldOnToyota is offline   Reply With Quote
Old 02-21-2010, 11:17 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Have you changed your car battery? It's about due, the low voltage when cranking may be causing the strange behavior....
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 04-04-2010, 08:26 PM   #3 (permalink)
Actually, I replaced the battery about 6 months ago. Since my last post, I noticed that the beeps happen when I turn the key to the on position, whether I crank the engine or not. I still have no idea as to the cause.
Old 04-04-2010, 08:29 PM   #4 (permalink)
"Circle of trust"
View catric69's Photo Gallery
Does the vehicle have an alarm system installed?
catric69 is offline   Reply With Quote
Old 04-04-2010, 10:29 PM   #5 (permalink)
Not that I am aware of, other than the stock factory system initiated by the alarm button on the key fab. I bought it used in 2008.
Old 04-04-2010, 10:55 PM   #6 (permalink)
Somewhat a Lurker
Gameroom cash: $311569
View Agent556's Photo Gallery
something screwed up in the wiring?
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 04-05-2010, 12:04 AM   #7 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
Only thing I can think of is that it's had an alarm installed in the past?
Check under the steering column and around the ignition harness, see if any of the wires are spliced into or if there is any aftermarket alarm modules hidden.
CamrySExxx is offline   Reply With Quote
