How to change tranny fluid on Gen6?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2010, 07:20 AM   #1 (permalink)
View ben805's Photo Gallery
Have a 2009 LE V6, as you know the gen 6 don't have a tranny dipstick to check the fluid condition, but I would like to change out the fluid at 30K miles anyway regardless what toyota said. Have you guys done it? if so....how??
2009 Toyota Camry LE V6
2005 Toyota Camry SE V6
ben805 is offline   Reply With Quote
Old 03-01-2010, 09:07 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Should be the same as the earlier GEN6.
Have your dealer do it or follow the procedures in TSB-TC014-07.
Failure to properly adjust transaxle fluid can cause transaxle shifting issues or
damage to the automatic transaxle.
Old 03-01-2010, 01:58 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Remove drain plug.
Drain.
Close drain plug.
Remove fill plug.
Fill until fluid overflows.
Close fill plug.
Turn on car.
Shift through the gears.
Wait 1 min.
Turn off car.
Add more fluid to fill plug until it over flowers again.
I believe thats it, same as any other automatic trans more or less
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-01-2010, 04:05 PM   #4 (permalink)
'07 XLE
Gen6
Originally Posted by darksparkz View Post
Remove drain plug.
Drain.
Close drain plug.
Remove fill plug.
Close fill plug.
Turn on car.
Wait 1 min.
Turn off car.
Wrong.........
Old 03-01-2010, 09:48 PM   #5 (permalink)
None Special...
lllDreaMz's Avatar
View lllDreaMz's Photo Gallery
Dont bother doing it...it has World standard in it, theres no point honestly..
It's Only A Camry Dude..
lllDreaMz is offline   Reply With Quote
Old 03-01-2010, 11:29 PM   #6 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
+1... there's no tranny dipstick for a reason... you don't need to change it
My Partial Partout!!!
Photo Album
Old 03-02-2010, 01:57 AM   #7 (permalink)
2GR FTW
darksparkz's Avatar
Originally Posted by njerald View Post
Wrong.........
Hm, I guess AllData Repair is wrong then, that's what i used to pull up the information for a 2007 Toyota Camry V6.
It'd be nice if you inform me what was wrong about it, so next time I know not to listen to AllData.
Old 03-02-2010, 03:24 AM   #8 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
i believe the changing interval is over 100K
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 03-02-2010, 11:41 AM   #9 (permalink)
'07 XLE
Gen6
I guess they are wrong then....those steps were not complete even for an old 2 speed auto.......
I'm not here to hold your hand........go to Alldata.
The Following User Says Thank You to njerald For This Useful Post:
gdanaher (03-15-2010)
Old 03-02-2010, 12:36 PM   #10 (permalink)
I don't care if it came with World Standard or Universe Standard fluid, all man-made fluid will break down eventually, there's no such thing as life time fluid.... it's just another way for Toyota to ripped off consumer. In few more years when more 6th gen approached 100~150K miles I'm expecting to see lots and lots of tranny failure from owners whom put their trust in these WS fluid to last for the life of the vehicle....even if these WS fluid consist of the highest quality synthetic fluid it will still break down, and exactly where are those metal shaving and particles from wear and tear circulating to? no where....since the tranny is supposely "sealed" so all that crap is looping indefinitely inside the tranny. I didn't see anything about filter needing to be replace on the pan either.
Old 03-15-2010, 02:01 PM   #11 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
I have really enjoyed the Toyota Nation Forum since I joined. 2004 Camry LE V6 ATF replacement. With atf at operating temp,remove drain plug on at and measure how much came out. On my 5 speed it was 4.5 qts. Install drain plug and torque to 36 ft.lbs.Fill at through dip stick tube with 4.5 qts of Toyota type T-IV. I used Mobil 3309 which I purchased from a Mobil jobber for $5.00 qt. by the case. Repeat this three or four times and you have just flushed your at just like the flushing machines used by the repair shops. Those flushing machines use the at pump in the torque converter to pump the fluid out and they replace new fluid back into the sump. There is no way I know of short of removing the sump pan and connecting some kind of a vacuum pump to the oil pickup above the filter to remove the atf from the converter. I didn't replace the sump filter. My Toyota dealer didn't even know the price of the filter,much less have one on the shelf. NAPA quoted me something like $48.00. I put 18 qts. through my at and the fluid looked like new. Has anyone else used this procedure to flush their at?
Donald E. George is online now   Reply With Quote
Old 03-15-2010, 03:18 PM   #12 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
I don't get it. You call "wrong" but don't say what's wrong about it. What's the point of that?
Redline_Me is offline   Reply With Quote
Old 03-15-2010, 03:44 PM   #13 (permalink)
Gameroom cash: $103555
View laphan's Photo Gallery
Here is how you change transaxle fluid for V6 gen6 camry:
http://www.justanswer.com/questions/...on-2009-avalon
'08 Toyota Camry Hybrid
'00 Grand Marquis LS (winter beater)
'04 Porsche Boxster
Gone: '06 Solara
laphan is offline   Reply With Quote
Old 03-15-2010, 03:56 PM   #14 (permalink)
'07 XLE
Gen6
I've all ready pointed out the TSB and Service manual.............
Old 03-15-2010, 04:30 PM   #15 (permalink)
Thanks for the info, i'm sure everyone appreciates it.
