coming to 100,000 miles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2010, 04:32 AM   #1 (permalink)
View camryguyOC714's Photo Gallery
thanks for helping guys, what should I need to take care before it my camry 2007 (4 cylinders) automatic transmission about 83,000 miles now. Do i need to change the timing chain? Or anything else in particular when it is at 100K miles. Thanks
camryguyOC714 is offline   Reply With Quote
Old 03-04-2010, 08:11 AM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Your car has a timing chain so no replacement needed. If you haven't had ur radiator flushed yet it would be a good idea to do that. And prlly a transmission flush too.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 03-04-2010, 11:25 AM   #3 (permalink)
View AlmightyCamry777's Photo Gallery
if you change the oil you will probably never need to change the timing chain.
I tore apart my old 1988 nissan pickup Z24 engine to change the timing chain. Because it had 250,000 miles on it. Come to find the gears and chain were clean, no bow on the chain once removed, no wear marks on either gears or chain and almost like new. and could probably have easily gone at least another 50,000 miles. ( a worn timing chain and gears can often be spotted just by removing the approriate covers andlooking at them - if worn the gears often have a round wear ridge under each tooth.) The only worn part was the tensioner, which on the nissan z24 engine is a spring-loaded rubber block.
This engine had its oil changed (dinon oil) every 2500 miles.
If i had to do it again i'd just replace the tensioner for $20 and let it go until the chain started making noise!
AlmightyCamry777 is offline   Reply With Quote
