Info on replacing engine air filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2010, 09:38 PM   #1 (permalink)
View OnePocket's Photo Gallery
I have a '07 Camry V6 LE. Will someone tell me the secret
for replacing the engine air filter. I un-hooked the three small vacuum lines and un-hooked the 3 clamps, but the
assembly won't raise up no more than about 1 inch. There
has to be more to be done. Any help appreciated.....thanks.
OnePocket is offline   Reply With Quote
Old 03-08-2010, 09:45 PM   #2 (permalink)
View lenjack's Photo Gallery
my wife's '10 is the same way. Although no need o change filer on brand new car, I was checking it out for future reference.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
Old 03-08-2010, 09:47 PM   #3 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
This has been discussed already. There is also a video.
Engine Air Filter Help...Please!
How to change engine Air Filter
It doesnt lift up. You'll have to slide it out in the tight space.
CarDomain
Old 03-09-2010, 09:20 PM   #4 (permalink)
If this has been discussed before, I can't find it. The ones I found all seem to deal with the I4 engine.
On the V-6, if it doesn't lift up more than an inch,then it's going to be very difficult to get it out and even more difficult to put the new one in without damaging it. There has to be an easier way.
Where can I find the video for replacing this filter?
Old 03-09-2010, 09:27 PM   #5 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
Elbow grease. Yes it is a pain in the ass but you can do it! Use your muscles.
Make sure it is oriented correctly and shimmy it in. It will not get damaged. I've done this like 4 times already and I always swear under my breath while doing it.
MJZ is offline   Reply With Quote
Old 03-09-2010, 09:40 PM   #6 (permalink)
must.resist.modding
bandit's Avatar
There is a video
If you want to remove the cover completely, there is a metal spring type that is on the top and a screw/clamp, slide that off and pull the cover off.
CarDomain
The Following User Says Thank You to bandit For This Useful Post:
OnePocket (03-10-2010)
