howling noise at speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2010, 09:50 PM   #1 (permalink)
View Heffymac's Photo Gallery
Anybody else have this problem. 2007 Camry xlt 4cyl. Have 51k miles on it. Getting pretty loud howling noise that is not tires. Starts at about 40mph, loudest at 71mph and lessens alot around 75mph. Out of warranty now so hope this isn't a major fix. This car been a headache from day one. Dealer is little help. Went to another dealer and they sent be back to the first one. Major water leak into car for first year went unnoticed due to unconnected drain tubes in moonroof. Entire headliner and carpet was replaced. Lots of rattles and squeaks now but am living with them as dealer won't do any more to fix them as well as reconnect radio antennea. 27000 dollare car with only on station working. Thats Quality?? Will dump this thing as soon as I can. Sorry to vent. Let me know on the howling thing.
Thanks
Heffymac is offline   Reply With Quote
Old 03-15-2010, 09:53 PM   #2 (permalink)
Somewhat a Lurker
Gameroom cash: $311569
View Agent556's Photo Gallery
can you describe a bit what the howling sounds like?
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 03-15-2010, 10:04 PM   #3 (permalink)
Sure...it sounds sort of like a loud hum like a tire would make with alot of off road tread. It is severe enough that I can feel it a little in the steering wheel. Hope this answers your question. Appreciate your response
Old 03-20-2010, 08:53 PM   #4 (permalink)
View valeoray's Photo Gallery
Could be a bad wheel bearing.
2007 Camry SE V6
valeoray is offline   Reply With Quote
Old 03-21-2010, 06:43 AM   #5 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
^ agreed. sounds like a bad wheel bearing. sound coming from the front or rear? does the sound go away when you turn? rear wheel bearings are far easier to replace than the fronts
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 03-21-2010, 07:37 AM   #6 (permalink)
Gorky_Park's Avatar
View Gorky_Park's Photo Gallery
Forget the dealer, they will charge you per hour at this point...go to your local trusted neighborhood shop and have them test drive it. They will tell you what is wrong, tell you how much it is going to be to fix it, etc. You can't describe a problem with "howling noise" because generally there could be several issues associated with it, including the bad bearing. Asking unqualified strangers is not the best way to diagnose the issue. Make sure your local meachanic is ASE certified.
I'm sorry to hear about your bad experience with the Cam, I personally have 66K miles and never had any issues other than maintenance
Good luck
Inbeforenjerald
2007 SE i4
Gorky_Park is offline   Reply With Quote
Old 03-21-2010, 08:28 AM   #7 (permalink)
Kotik's Avatar
View Kotik's Photo Gallery
When I just got my car I also had terrible sound from 40 mph and up. I thought about bearings and could not believe that tires are so loud. But sound was gone completely when I switched to winter tires.
2007 Camry I4 SE with some additional plastic, carbon-like hood and window tint
Kotik is offline   Reply With Quote
Old 03-21-2010, 01:49 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Wheel bearing sounds usually increase with speed and probably won't show up just in a range and then disappears/lessens. Might want to check tires (balance/rotate) and alignment. What brand of tires are you using?
You can check to hear if the pitch changes in S-turns. Find a safe lot to do this. The noise on the bad wheel bearing increases with load (for instance, on the outside of a turn).
As far as the lesser quality of today's Toyota, I think the grandson Toyoda also agrees with you about the MBA bean counter types flushing the family name down the drain. I like today's Detroit powertrain enginnering but still think their packaging looks like the designers have never seen an iPod or iPhone.
Thanks
