Where to jack my car up? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2010, 12:12 AM   #1 (permalink)
olympicgold's Avatar
View olympicgold's Photo Gallery
Gen5 Where to jack my car up?
Hi guys. I am kind of new to DIY but I've done several things before: changing spark plugs, taking dashboard apart to replace LEDs, etc but right now I need to change the brakes.
It is kind of confusing: manual says that I should use 2 jack "spots" under the front bumper to jack the car up. But I think it would not let me jack high enough to lift tires up.
I have looked where I can place jack on the side of the car near the wheels but it looks like it's all plastic all around and I have no clue where to place the jack... There are some metal spots but they do not look flat. Maybe can someone take a pic for me and show where to place jack? I have floor jack.
Gen 5 camry
olympicgold is offline   Reply With Quote
Old 03-20-2010, 12:24 AM   #2 (permalink)
Somewhat a Lurker
Gameroom cash: $311569
View Agent556's Photo Gallery
there should be a spot under the car in the front that looks like a little bulge. its in the center.
this diagram should help
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 03-20-2010, 12:29 AM   #3 (permalink)
Yeah I saw this spots on side of the car for jack. The problem is that I do not have original jack that is made for those spots. I have floor jack with 'round' lifting component. Do you think that thin line would bend if I place jack there?
Old 03-20-2010, 12:39 AM   #4 (permalink)
Somewhat a Lurker
if your floor jack is has a large enough lifting plate, you should be able to put the jack under the front of the car, to the jacking point on the front crossmember. refer to the top-down view of the car in the image above. if the plate is small, it may be able to fit right in the notches on the side of the car.
2005 Camry SE V6
Old 03-20-2010, 08:18 AM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
idk if those notch do anything but when my OEM jack put in, it seems smaller than the notch. I think those notch just markings to indicate the best spot to jack along that beam.
workerant is online now   Reply With Quote
Old 03-20-2010, 11:37 AM   #6 (permalink)
Gameroom cash: $303755
Go to the Camry forum over at AutomotiveForums.com and download the Toyota factory service manual for the generation 5 Camry. The manuals are stickied there at the top. It will show you the jacking points along with a lot of other usefull information you will need in the future.
I would also recommend going to a salvage yard and picking up an original jack and jack handle for your car. You never know when you might need it.
Mike
Old 03-20-2010, 12:57 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Any place on the frame or pinch weld and you'll be fine.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 03-20-2010, 07:54 PM   #8 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Mike
I found a piece of oak off a pallet and cut it down on my table saw to fit my floor jack pad. I also ripped a 3/16'' slot in the middle of the block so I can use the jack to jack at the side front and back jack points. Works for all jack points on my camry.
Donald E. George is online now   Reply With Quote
Old 03-20-2010, 11:08 PM   #9 (permalink)
View rsb1445's Photo Gallery
Are the jack positions the same for Gen 6 Camry?
rsb1445 is offline   Reply With Quote
Old 03-20-2010, 11:20 PM   #10 (permalink)
Somewhat a Lurker
yes, they should be similar.
also, im curious... do they have the jacking positions in the owners manual?
also, to quote blackcamryse
"Any place on the frame or pinch weld and you'll be fine."
2005 Camry SE V6
Old 03-20-2010, 11:49 PM   #11 (permalink)
^ I did see it in my gen 6 owner manual.
Old 03-21-2010, 04:05 AM   #12 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
^ i saw it in my gen 5.5 manual too.
aznlunatic206 is offline   Reply With Quote
Old 03-21-2010, 07:42 AM   #13 (permalink)
View cb900f2's Photo Gallery
Canada
Hey guys.. Do what I did, get four hockey pucks and cut a slot in them, and try to find some flat top jackets and then bobs your uncle..
http://www.yarisworld.com/forums/showthread.php?t=9823
cb900f2 is offline   Reply With Quote
Old 03-23-2010, 05:55 PM   #14 (permalink)
View hossmaster's Photo Gallery
yes a small portion of the pinch weld will bend. I use a floor jack on mine all of the time. It won't hurt anything and I trust my floor jack more than that scissor jack any day. Mountain out of a mole hill.
hossmaster is offline   Reply With Quote
