v6 2002 trunk wont open - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2010, 11:36 AM   #1 (permalink)
flo
View flo's Photo Gallery
i just tried to reprogram the remote, the locks go tru their cycle and everything but the trunk still wont open.
when i press the remote to open the trunk i have to wait some 3 seconds until i get a beeping sound, and thats it, any sugeestions what could be wrong, it has never worked in the 4 years i own it now, but i cant imagine theres something broken.
flo is offline   Reply With Quote
Old 03-20-2010, 12:01 PM   #2 (permalink)
flo
i have to add, that when i lock the doors, turn the alarm on and open the door from inside, the alarm doesn't go off.
the ONLY key i have also only works at the drivers door.
Old 03-20-2010, 12:25 PM   #3 (permalink)
Toyotaholic
View jkchang's Photo Gallery
If you are hearing the long beep, that means the computer is telling the lock to release. You should hear a metal "click" noise to indicate the solenoid engaged (near the center rear of the trunk).
1. Does the trunk open when you physically pull the lever? If so, it may be a bad release solenoid in the lock assembly. If it is not releasing, the lock itself may be bad. I think the solenoid may be build into the lock itself, so either way, you're SOL.
2. Check if the trunk is in valet lock mode. Use the key to unlock the trunk. The key insertion should be verticle |. If it is horizontal -, then it was in "valet lock mode". The solenoid was engaging, but the lock was just shaking its head thinking "Nice Try!". I don't remember which year they added the trunk lock at the cylinder though~ pretty sure it was in the 2002 and up.
Hopefully that will push you in the right direction.
jkchang is offline   Reply With Quote
The Following User Says Thank You to jkchang For This Useful Post:
flo (03-21-2010)
Old 03-21-2010, 10:41 AM   #4 (permalink)
flo
the trunks lock is vertical, so im guessing it is in valet mode.
now as i said my key only fits on the drivers door, and that's the only one i have. is there a way i can get it out of valet mode without the right key ?
the only way i can open my trunk is from the little pull thing under the drivers seat
thanks for any help
Old 03-21-2010, 01:03 PM   #5 (permalink)
Somewhat a Lurker
Gameroom cash: $311569
View Agent556's Photo Gallery
if you can open your trunk from the lever under the driver's seat, your trunk is not in valet mode.
dunno if your key is the valet key though...
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 03-22-2010, 06:57 PM   #6 (permalink)
Toyotaholic
Possibly the key cylinder was changed out (are you the original owner?) if it doesn't work in the trunk. If the handle under the seat to open it is working, it sounds like the lock assembly's solenoid is out.
