Originally Posted by gdanaher
Ethanol is being used nationally and the fuel mileage goes down proportionately. Things to check include making sure the tires are as hard as you can stand them, keep a clean air filter, clean the air intake system occasionally, put a little bottle of RXP in the gas maybe once a year, and yes, wash the car. The dirt on the outside creates drag and lowers gas mileage.
I will elaborate a little.
I like to keep my tire pressure at 35lbs psi.
I agree have a CLEAN air filter (I use a K&N... stock replacement).
When was the last time you changed the spark plugs (I change mine every 50Kmiles).
How new are your tires? (new agressive tires will lower you gas milage) my winter tires lower my gas milage by 15%. Are you using stock RIMs? Cheap aftermarket RIMS are usually HEAVY and that will also nock maybe 15% off your fuel economy. Last thing, when my tires start to get bald, I usually increase my economy by like 15%, so when you noticed your economy years ago maybe the tires were low on tread.
I'v never used RXP and after googling it I don't know if I would use it.
But I do use one additive... techron fuel injection cleaner, buy it a walmar and I use one or two bottles a year "read the directions" but I am not sure if this will hep your fuel economy.
