yes, you can do it yourself. i assume you know how to get to and clean throttle bodies in general, so i'm just going to describe getting the plate open.
if you're concerned about damaging the motor that controls the throttle body plate position... one way is to turn the key to on (but DO NOT START!) and use a brick or something heavy to hold down the gas pedal, which will open the throttle body plate.
the other way is the conventional way: just to pry it open with something non-marring and use something again non-marring to prop it open. i've done this several times to no ill effect (at least none that i know of) but do both methods at your own risk.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
