Originally Posted by dnossirb
I've got the correct part #'s now. They are 86180-0w032 and the fitment kit is pt546-33100.
I asked the dealer if they had a copy of the wiring diagram or if they knew where these parts installed and of course the parts guy knew nothing and the service guy knew even less. The instructions they sent me said '10 on them but they look a lot like the '09 and earlier where you have to tear the whole car apart to run the wires. I have a feeling the install is very simple in a 2010 Camry.
I found two connectors in the left side of the trunk does anyone know if these are the only connectors I need. Or will I seriously need to tear the car apart to install XM.
I don't know anything about those two connectors you speak of. I have an 07'.
As for "tearing the car apart"....its just a few panels here and there that need to be removed...It's actually pretty easy.
Radio, Door Panel, Rear Deck & Tweeter removal for CE, LE, SE & XLE DIY; 56k Beware
I would first test out those connectors that you have in the trunk.
All you are doing is plugging in the sat radio antenna. If your account is active, then it should turn right on for you.
