Shaking when Braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2010, 08:17 PM   #1 (permalink)
Camry Lover
View blingblingtivoli's Photo Gallery
I have a 09 Camry and the steering wheel shakes a lot when I break.
I am totally clueless when it comes to cars, can someone please help me out?
blingblingtivoli is offline   Reply With Quote
Old 04-04-2010, 08:21 PM   #2 (permalink)
Polish Pleasure Member
View EuroPlate's Photo Gallery
Most likely a warped rotor...depending on how many miles you have on it is still might be covered under warranty...
2007 Camry SE V6 - Titanium Metallic w/ Dark Charcoal - JBL Audio - Sunroof - Rear Spoiler - Auto Dimming Mirror w/ Homelink - 30% LLumar Tint - VG Shark Fin - SoundLinQ2 Sirius Kit
I AM THE STIG
EuroPlate is offline   Reply With Quote
The Following User Says Thank You to EuroPlate For This Useful Post:
blingblingtivoli (04-04-2010)
Old 04-04-2010, 08:21 PM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
The front brake discs are warped.
This is a common issue and has been happening since the 2007 model year onwards.
The first set of brakes on my 2007 Camry developed warped front discs. I had them re-machined twice and after that I did a full brake job.
My second set of brakes have also developed warped front discs. Next week I'm having the surface of those discs re-machined.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
The Following User Says Thank You to Yazovets For This Useful Post:
Old 04-04-2010, 08:23 PM   #4 (permalink)
Camry Lover
How much did you pay when you fixed your brakes?
I just don't want to get ripped off by the local mechanics
Old 04-04-2010, 08:29 PM   #5 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
check the wheel balancing and alignment especially if the shaking is more pronounced when you brake at higher speeds. 95% chance you just need to get your wheels balanced.
with a warped rotor you will usually get an odd pulsating kind of feeling moreso than a shaking in the steering wheel when you brake.
ScrooYoo is offline   Reply With Quote
The Following User Says Thank You to ScrooYoo For This Useful Post:
Old 04-04-2010, 08:32 PM   #6 (permalink)
Camry Lover
my steering wheels shake when i'm breaking to exit freeways
local driving is a little bit better though
Old 04-04-2010, 08:41 PM   #7 (permalink)
yup. definitely sounds like you need to get your wheels balanced. Go to a good reputable shop that specializes in tires (jack-of-all-trades type garages won't do a good job and won't have the best balancing equipment.)
Get all four of your wheels balanced and see if that doesn't fix the problem.
Old 04-04-2010, 09:05 PM   #8 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
HA!!!!!!!!!!!!
Old 04-04-2010, 09:08 PM   #9 (permalink)
Proliphik's Avatar
View Proliphik's Photo Gallery
google is a great tool...
08 SE - LE GRILLE - LED FOLD MIRRORS - LED TAILS - SWITCH BLADE KEY
TBW INTERIOR ACCENTS - LEATHER/SUEDE SEATS - MTEC H9 LOWS & FOGS
JBL SYSTEM - OEM NAVIGATION - ROOF SPOILER
Proliphik is offline   Reply With Quote
Old 04-04-2010, 09:16 PM   #10 (permalink)
Originally Posted by njerald View Post
HA!!!!!!!!!!!!
care to explain?
Old 04-04-2010, 09:19 PM   #11 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
If the steering wheel only vibrates when you are hitting the brakes, you should get your brake rotors resurfaced. I am not 100% sure, but I think this costs around $80-120 or so for each pair of rotors. Most shops will suggest that you replace your brake pads when you resurface your rotors so it would probably cost $150-200 for new pads and resurfacing your rotors.
Keep in mind that resurfaced rotors have less material and therefore are more susceptible to warping, but the cost for new rotors is an additional $200 or so for the pair so your total brake job would probably be around $400.
How much mileage do you have on your car?
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is online now   Reply With Quote
The Following User Says Thank You to thrawnis For This Useful Post:
Old 04-04-2010, 09:24 PM   #12 (permalink)
09 Silver Bullet's Avatar
View 09 Silver Bullet's Photo Gallery
Do you feel the brake pedal (throbbing) and the steering wheel shaking at the same time when it happens?
09 Silver Bullet is offline   Reply With Quote
The Following User Says Thank You to 09 Silver Bullet For This Useful Post:
Old 04-04-2010, 09:26 PM   #13 (permalink)
Last time I had rotors turned, it costed about $15 each. I of coarse removed them myself and took them in. It will cost more if you just take ur car in.
Old 04-04-2010, 09:28 PM   #14 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
I had the exact same issue with my 2007 with 33k camry
i had alignment done and my steering wheel was still shaking when braking from 70mph exiting a freeway.
if the steering wheel vibrates driving at high speeds then most likely need balancing.
if the steering wheel only vibrates when braking, then most likely rotors and brakes.
when I checked my pads, there were still more than enough.
since then, i've done a balancing and rotation and it has helped a little bit but i know the problem is still there. It's not too bad so I won't get it fixed yet. My front struts are also leaking so i need to narrow down to struts or rotors being warped. as many people here say, dont' get it machined, just get new ones. they're not that expensive.
skyxliner is offline   Reply With Quote
The Following User Says Thank You to skyxliner For This Useful Post:
Old 04-04-2010, 09:38 PM   #15 (permalink)
It all depends on who performs the repair on it to determine the cost. If he does it himself, not too bad, maybe $200 for pads and rotors. If he has a shop do it, he's looking at close to $400. Even if he just wants to change the rotors, not a good idea, he needs to replace the pads also. Never replace one without the other. Just my 2 cents!
