I have a 2004 Camry with what is the most odd noise I've ever heard.
The noise sounds like a cross between water trickling over stones and maybe bearings rolling around in a tube, or maybe someone crinkling paper. It sounds like it is coming from inside the dashboard, or maybe just beyond the firewall in the engine compartment.
It tends to occur when the vehicle is stopped and is just starting to accelerate from a stop. It can also occur when the vehicle is breaking to a stop. It doesn't sound like break pads (not grinding metal-on-metal sound).
At a stop, I can shift the automatic transmission into neutral and rev the engine a little and the sound will occur, but it doesn't seem to be dependent on any specific RPM nor does it co-vary based on increases or decreases in RPM. Basically, when I rev, the sound simply occurs. It is of variable intensity and duration, and is very random in peak of volume and sequence of noises. If I didn't know better, I'd swear there was a chipmunk under the hood (I looked, there isn't.)
I drive the car daily, but my regular trip to work is very short so the car runs for no more than 5 minutes each morning. In a five minute drive, with 4 stop sign/lights, the noise will occur basically every time I accelerate.
Any idea what this is?
