Anyone run a high output alternator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2010, 01:33 PM   #1 (permalink)
View so cal eddie's Photo Gallery
I have a 2002 se 4cyl and Im considering the 140 amp unit from maniac. Has anyone had any issues with these? I've installed high output alts in other cars, but some of them induce a lot of noise. I have a newer alternator off of a 2006 with the 100 amp rating that I haven't installed, but I don't think it will work for my setup. Any input would be appreciated. Here is the alt Im considering.
http://www.maniacelectricmotors.com/hiou140ampal1.html
so cal eddie is offline   Reply With Quote
Old 04-11-2010, 01:59 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
what kind of setup you planning to do?? audio system?
LoudCamry is offline   Reply With Quote
Old 04-11-2010, 02:13 PM   #3 (permalink)
Well here is the rundown
-Dynaudio mw180s in the doors
-Dynaudio mw150s and md100s in the kicks
-Dynaudio mw150 and md100 for center channel
-mw180s and md100s in the rear
-4 oz audio 250 subs in the rear deck
-2 alpine pdx 4150s
-1 alpine pdx 2150
-1 alpine pdx 11000
-alpine monitor, surround sound processor, changer, navigation
-a few other things
The goal is for a stealth setup.
Old 04-11-2010, 03:55 PM   #4 (permalink)
LoudCamry's Avatar
i think you should be fine with the stock 100amp alternator. just do the big 3 upgrade with 1/0 wires with 2 battery with isolator.
Old 04-11-2010, 04:04 PM   #5 (permalink)
My only problem is still trying to figure out how to adapt the 4 wire plug of the 100 amp alt to the 3 wire of my 02 80 amp alt. I mocked it up in the engine bay and everything lines right up, the only issue I'm having is the wiring. The upgraded alt from maniac is the 3 wire and plugs right in. This is why I'm leaning towards this.
Old 04-11-2010, 06:52 PM   #6 (permalink)
LoudCamry's Avatar
what do you mean by ''how to adapt the 4 wire plug of the 100 amp alt to the 3 wire of my 02 80 amp alt. I mocked it up in the engine bay and everything lines right up"?
Old 04-11-2010, 07:01 PM   #7 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $528010
View BlackCam09's Photo Gallery
im running a 200amp h/o in my 09 camry. i had it custom built by excessive amperage.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 04-11-2010, 07:19 PM   #8 (permalink)
View Shelbrain's Photo Gallery
Did the new alternator negatively affect your mileage? Did it introduce any noise into the system. Do you notice any difference in how the vehicle drives? What made you want to upgrade the alternator, were you having problems prior? How many watts are you running?
Shelbrain is offline   Reply With Quote
Old 04-11-2010, 07:37 PM   #9 (permalink)
this is how my stock alternator looks
The alternator that I bought is off of an 05 4cyl and it has 4 wires instead of 3. This is where I am stuck.
Old 04-11-2010, 10:02 PM   #10 (permalink)
2007 CAMRY XLE V6
View azntuner8's Photo Gallery
me too lol, alternator is an absolute beast!
[/SIGPIC][/SIGPIC]20"TIS 12s,NT555s,MEGAN COILS,6kHIDS,200ampALTERNATOR,2SHUREKIN BATTERIES,PIONEER AVH-P4200,VIZUALOGIC TVS,JL 10W7s,1000/1v2,300/4v2,FOCAL165 K2Ps,E&G GRILL,WOODGRAIN STEERING WHEEL,CUSTOM TWO TONE SUEDE INTERIOR,FUTURE MODS-BAGS,SUICIDE SHAVED DOORS,WHEELS N PAINT JOB
azntuner8 is offline   Reply With Quote
Old 04-11-2010, 10:39 PM   #11 (permalink)
So, do you guys have any issues with these high output alts?? I've had trouble with mechanical man and ohio generator stuff in the past. Mainly, some of them induced engine noise and had more of a "winding" sound to them. Do you mind telling us the price paid for these custom units? Maybe by pm if you don't want others to know. Thanks.
Old 04-11-2010, 11:21 PM   #12 (permalink)
LoudCamry's Avatar
I don't know anything about the 4 wires plug from the 05-06 mode, but altetnator winding usually come from a bad grounding.
"Check all your grounds, clean up the connections etc. make sure all of your amp grounds connect at the same point...not the battery (clean batt terms/add/cleanup ground strap connections). Also, make sure your using proper signal cables, shielded...away from sources that could give noise...comps/large wiring harnesses etc.
Also, make sure that your gains are adjusted correctly. Make sure no speaker wires are shorting to ground. Check connections at your headunit."
Old 04-12-2010, 12:32 AM   #13 (permalink)
The winding that is inherent with certain types of high output alts has nothing to do with stereo installation, upgraded grounds, wiring, etc. You can simply hear the alternator sounding like a poor excuse for a supercharger. Some brands are notorious for this. I've had great experience with mechman and old school stinger alts for domestic applications, but not such great results for imports. I've installed dozens of alts, and it's hard to tell what is going to do the trick. I will probably just end up with that maniac alt and give it a shot. The price seems pretty good, so we will see.
Old 04-13-2010, 01:53 PM   #14 (permalink)
Here are the pics of the 4 pin alt. If I can't figure out how to make it work with no issues, then I will likely try the maniac one.
Old 04-13-2010, 08:39 PM   #15 (permalink)
steveyhustle's Avatar
View steveyhustle's Photo Gallery
Let me tell you, you dont need a HO alt for that setup. I currently run 2 PDX amps 2.150/4.150 and a 3500 watt amp that does about 4000 watts and im running at .5ohm which puts more stress on my alt. BUT i do have a upgraded batt under hood 4 runs of 0gauge and 2 batts in rear and big 3 done. With that I dont drop below 13vs at full tilt on stock alt. With the setup your running you will be fine no need for a HO alt. I plan to get one from DC Power soon but only because Im running 8k + soon. I compete in car audio. Have any questions let me know. Heres some pics of my setup i used to have..
Catch me in ya city,
Sittin Pretty,
You know im shinin' dog!
steveyhustle is offline   Reply With Quote
