2007 V6 misfires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 04:36 PM   #1 (permalink)
View jhender31's Photo Gallery
2007 V6 misfires
Hello all
My 2007 v6 camry is misfiring and registering codes
P0300, and P0356 which indicates coil "F" which I believe is cylinder 6. Can someone help me determine if this is correct and the ordering of the cylinders? I think I read 1,2 and 3 are in the front and 4-6 in the back.
Thanks guys.
jhender31 is offline   Reply With Quote
Old 04-20-2010, 04:58 PM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
does your car pop?
GT-R is online now   Reply With Quote
Old 04-20-2010, 05:48 PM   #3 (permalink)
Re
I am not sure what pop is but the car does vibrate slighty, especially when idle.
Old 04-20-2010, 06:05 PM   #4 (permalink)
View TAZCOOLS's Photo Gallery
Need more info, Miles? first thing i would do is replace plugs and wires. its the cheapest thing to do and probably should be done anyways or at the very least it cant hurt. run car at night, somewhere very dark, do you see arcing? then you most definitely need wires. If you get wire don't buy the cheapest set.
TAZCOOLS is offline   Reply With Quote
Old 04-20-2010, 06:11 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
The cylinder 6 coil is failing. Perhaps a loose connection, so pull the wire and take a look, but with less than 120,000 miles on the clock the plugs should be fine. I'm guessing that the previous suggestion to look for arcing on the plug wires comes from someone who hasn't seen this engine.
gdanaher is offline   Reply With Quote
Old 04-20-2010, 06:31 PM   #6 (permalink)
Re:
Thanks for the suggestions but I just wanted to know where is cylinder 6 located. I already suspect the cylinder 6 coil may be faulty and wanted to swap and see if that helps\changes the codes.
Car has just over 100k miles on it so I do not suspect the plugs at this point and since the P0356 indicates cylinder 6 that is what I am looking for.
