Front Right Creak Noise - Bushings or Body Cowl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2010, 08:14 PM   #1 (permalink)
View tn88888888's Photo Gallery
Experiencing a quiet creak (not rattle or squeak) from the front passengers side occasionally while moving from stop, coming to a stop, turns and bumps. Jacked up the right side and inspected the wheel area and underbody -- couldn't find anything superficially wrong. Has anyone experienced a similar noise?
I found two toyota bulletins that may match this symptom: Stabilizer bar bushings (posted here by SPL) and a Body cowl/fender creak (google search). Has anyone done the Body cowl TSB?
Is there any way for me to inspect the bushings? The bulletin says its a lubrication problem, could I just try to apply some high temperature grease to the bushing?
The Body cowl and fender creak seems impossible to verify without some disassembly. The fix would require re-do welding and then using a crow bar to separate the cowl from the inner fender.
TSB:
Body Cowl and Fender Creak
T-SB-0055-09
January 30, 2009
2007-2008 Camry, Camry HV
http://www.toyotapartsandservice.com...S/T-SB-0055-09 n.pdf
tn88888888 is offline   Reply With Quote
