Car squeaks at low speeds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2010, 10:38 AM   #1 (permalink)
ayz
View ayz's Photo Gallery
I have a 2005 Toyota Camry LE. It drives just fine at high speeds, but at low speeds (5-15 mph) there is a repeated squeaking sound coming from the left, almost sounding like a squeaky wheel.
I don't think it's the brakes since I have had the brakes replaced (and broken in), and this happens when cruising at low speeds without a foot on the gas OR break.
Any idea what might be causing this? Something wrong with the axle or something? After I had my tires rotated/rebalanced it didn't help either.
ayz is offline   Reply With Quote
Old 04-30-2010, 10:30 AM   #2 (permalink)
ayz
bump. anyone?
Old 04-30-2010, 11:23 AM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Could be the struts, or springs...could be anything.
Mine does the same but i think it is the foam block behind the rear seats (when you fold them down) i think it is rubbing and squeeking. I keep forgetting to check it out.
2002 Camry SE V6 "Snow White"
Old 04-30-2010, 03:15 PM   #4 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
try to have someone ride along and pin point exactly where the squeeking is. could be so many things.
WrongFitmentCrew#628
Old 04-30-2010, 07:32 PM   #5 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
You know my car does the same thing. Most noticeably when rolling around slowly with the clutch in. The mechanic couldn't find it (bizarrely the noise went away that day) and said the brakes were fine, so I have to find the time to take it in again. Bah.
If i jack the car up and spin the wheel by hand I can hear the faint sqeak.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 04-30-2010, 09:06 PM   #6 (permalink)
Paul_09WhiteV6
sounds like something contacting. u said brakes were done not too long ago? is it possible they forget something when installing or didn't use oem components?
Old 05-01-2010, 05:41 PM   #7 (permalink)
View VVT-iT's Photo Gallery
you could have loose belts or improper brake installation or maybe the caliper piston doesnt retract all the way back? which would cause the squeaky noise. does that make sense?
07 Camry LE 2.4l
VVT-iT is offline   Reply With Quote
