Originally Posted by Harry6
autozone has no such puller / tool
hey i just did mine on tuesday, on my 03 SE 2.4L..
took me 45mins to do, not including draining the radiator..
i got the pulley off the same way this guy did
while the tool would be more ideal, his method worked fine.
Dealer wanted like 146 for the waterpump, i found oem ones online for 116.. but with the dealership pumps seeming to fail so fast, i just went to advanced auto parts and picked up there waterpump for 54 bucks.. it actually seemed pretty descent..
the advance auto one came with a cheap looking gasket, the factory waterpump doesn't even use a gasket, just like RTV sealer, i'd recommend getting the dealers stuff to seal it, it's called "FIGP" i cleaned the old sealant off the block with a razor and applied the FIGP to the new waterpump, put everything back together and i personally let it sit overnight, but the FIGP stuff says you can start the car in a hour or two, but doesn't set until 15-16 hours..
i also picked up a bottle of the super long life coolant from toyota it was 19.99 the FIGP from the dealer was 13.69 ..
when i drained my radiator fluid though i drained it in a clean pan, when refilling the radiator i used my new bottle of coolant, then i filtered the pan of old coolant through a screen or cloth, back into the coolant bottle, so i could reuse it if i needed extra. kind of a cheap move but, i didn't want to have to buy another bottle of coolant from the dealer, and the coolant i drained was very clean still and i didn't need much of it at all..
let me know if you have any questions though.. i just did it the other day, was the easiest waterpump i've ever done..
don't know if i was on the stock one or not, but my car has 131k on it.
here's a video of how bad mine sounded before i changed it!
