2011 camry steptronic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2010, 10:38 PM   #1 (permalink)
View ylen13's Photo Gallery
I search and didn't see this talked about. In 2011 camry, is steptronic still gear limiter or did they finally put a real manual steptronic shifter?
ylen13 is offline   Reply With Quote
Old 04-28-2010, 10:43 PM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
it's still the same.
GT-R is offline   Reply With Quote
The Following User Says Thank You to GT-R For This Useful Post:
ylen13 (04-28-2010)
Old 04-28-2010, 11:03 PM   #3 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
it will shift a bit faster than normal but nothing like manual.
WrongFitmentCrew#628
The Following User Says Thank You to Pawel062 For This Useful Post:
ylen13 (04-28-2010)
Old 04-28-2010, 11:16 PM   #4 (permalink)
I expected to get this answer but was hopping that they would make it better
Old 04-28-2010, 11:21 PM   #5 (permalink)
Paul_09WhiteV6
it will work in snow kind of like a manual where u can use the gears to slow down the tranny and it will let u get to higher rpms but still won't be like a true manual. it's still fun to use and if u use it often enough it will learn to shit pretty quick.
Old 04-28-2010, 11:31 PM   #6 (permalink)
D33P$3T
Gameroom cash: $242152
View nitrous3's Photo Gallery
Quick question. Is it bad to use steptronic mode whenever you drive the car, like almost all the time? Shifting between 3-4rpms?
Update Thread : http://bit.ly/MExNcW
nitrous3 is offline   Reply With Quote
Old 04-28-2010, 11:38 PM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
It's not "bad" to use it. You'll end up shifting just as much as it would on its own anyway.
But there is no need to shift at 3000-4000rpm. That's way too high for daily usage. The V6 engine would have you taking off if you waited for 3000-4000rpm to shift.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 04-28-2010, 11:53 PM   #8 (permalink)
Paul_09WhiteV6
yea should be ok though shift a bit earlier. doing it once in a while is ok but not all the time. manuals u can shift later but automatics should shift sooner.
Old 04-28-2010, 11:54 PM   #9 (permalink)
I ♥ (.Y.)
GT-R's Avatar
more RPM means more gas!!
Old 04-29-2010, 08:17 AM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
I only use mine if I'm at a red light. Or coming up to a red light. At wot I shift it at about 6200. Right before redline. She screams.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 04-29-2010, 11:06 AM   #11 (permalink)
D33P$3T
Yea I was using it today and I shift at 3,000. I wish it didn't lag when your using it. I don't use it all the time either. Sometimes I accidentally forget that I put it into steptronic mode and it goes up to 5,000 in the lower gears lol
