Generation 5 Transponder Key (04 LE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2010, 05:48 PM   #1 (permalink)
View citrxj's Photo Gallery
Hey, I ordered one of those transponder keys off of ebay, and trying to reprogram it right now. I have a 2004 Camry LE V6, and I'm trying to figure out what is the correct instruction for programming this model? (I've seen about 3 different variations).
citrxj is offline   Reply With Quote
Old 05-05-2010, 11:08 AM   #2 (permalink)
First Toyo was '69 Corona
RickF's Avatar
View RickF's Photo Gallery
I have the programming instructions for 2002 to 2006 Camry. It's for the RS 3200 Security System. If your FOB shows an FCC ID of: GO43VT14T, it should work. See image below for instructions:
Hope this works for you.
2005 Camry 2.4L
2AZ-FE I4 — 2009 Camry 2.4L 2AZ-FE I4
RickF is offline   Reply With Quote
Old 05-05-2010, 05:07 PM   #3 (permalink)
Thanks, but that's the keyless entry system (or remote fob)... I have a regular key, but I need to program the chip inside it.
Old 05-05-2010, 05:55 PM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
Isn't the keyless don't have a ignition key hole?
workerant is offline   Reply With Quote
Old 05-05-2010, 06:01 PM   #5 (permalink)
Gen 5 didn't come with a push-button.
Old 05-05-2010, 07:07 PM   #6 (permalink)
^ than how do u start the car with the keyless? Or is it just to get into the car? that would be stupid to get into the car without the key and than needing the key, defeat the purpose of keyless.
Old 05-05-2010, 08:46 PM   #7 (permalink)
Keyless here means the remote lock/unlock... you know the little black rectangle on the keychain? That comes with pretty much every key before 2005?
Old 05-06-2010, 08:19 PM   #8 (permalink)
Bump.. anyone with the right instructions for the camry key?
2004 Camry LE V6
2010 Genesis Coupe 3.8 Base
