gen 6.5 dome light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2010, 10:20 PM   #1 (permalink)
View scoop713's Photo Gallery
gen 6.5 dome light
is there a way to remove the dome light? i was trying to install the led dome light but i happen to push it in too hard and now the switch from on-off-door is pushed up too high and i cannot get access to it unless i take the frame apart. anyone know how to do this? thanks
scoop713 is offline   Reply With Quote
Old 05-06-2010, 11:46 AM   #2 (permalink)
TN User
DemonicZia's Avatar
View DemonicZia's Photo Gallery
Take off the two rectangle covers that are at each end of the light. They will reveal two tabs that you can push inwards ( looks like a piece where you take a flat screwdriver and move it aside ), with a slight pull, that will take off the housing from the roof liner. Then you have access to the switch part. just line up and push in and it will snap back into place. Same thing happened to me, had to learn the hard way. Good Luck!
DemonicZia is offline   Reply With Quote
Old 05-06-2010, 11:56 AM   #3 (permalink)
Yea I did that pushing the two tabs in but it seems that something else is still holding the plastic frame in place (the two tabs are on diagonal corners but the other two corners won't release). Is there some kind of trick to it?
Old 05-06-2010, 02:05 PM   #4 (permalink)
TN User
DemonicZia's Avatar
Try pulling down while moving it left to right. There are two hooks by the tabs also holding it onto the liner. The side to side motion worked for me.
Old 05-06-2010, 04:27 PM   #5 (permalink)
Almost broke it. I think Ima just leave it on door and let it be.
