Toyota Platinum extended warranty(VSA), what's NOT covered that I should be aware of? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2010, 04:28 PM   #1 (permalink)
View ToyotaLexus's Photo Gallery
USA Toyota Platinum extended warranty(VSA), what's NOT covered that I should be aware of?
yes, I realize there are several other threads talking about Toyota's extended
warranty plan(VSA, or Vehicle Service Agreement)... but most of them talk
about the cost of the plan, and the pros & cons of whether the plan is worth it.
My question is limited to the following:
I will be purchasing the 8yr/100k Platinum(covering almost everything)
plan for my Camry for sure. I have researched this issue as much as I could,
either here or on other websites.
I downloaded the coverage brochure fom Toyota's own website and read it
from cover to cover. It pretty clearly spells out what is covered. However,
it doesn't really tell me what isn't covered. The brochure obviously says
anything not listed is non-covered.....
...but what other components are likely to suffer a defect/failure and fall
into the non-covered category? Obviously, I wouldn't expect them to
cover items caused by normal wear&tear, or damage from accident/fire/theft/
vandalism, or acts of god/nature, or war/terrorism...
for example, the brochure does say the heater core is covered.... but the heater
hoses are not. let's say the heater hose is leaking and it's located behind the
dash....sounds like a pretty simple job, but if it require the removal of the entire
dash(like on my Lexus), the it's probably going to cost $$$... and not covered?
Thanks for any info!
ToyotaLexus is offline   Reply With Quote
Old 05-09-2010, 12:16 AM   #2 (permalink)
View bluesy's Photo Gallery
I'm not entirely sure on this since I haven't read the warranty you're referring to. However, based on my previous extended warranty woes the situation you describe with the heater hoses would mean you foot the bill for everything related to the repair.
Also, the thing that bit me hard core - catalytic converters are not covered (at least by the warranty I had) and part of the pre-cat could very well have gotten sucked back into the engine (seems to be a not common, but not entirely unheard of situation with my previous vehicle) which would score the cylinder walls and essentially cause irreparable damage to the engine. Since a non-covered part damaged a covered part the entire thing wouldn't be covered. I chose to dump the car before I had the engine torn down to find out if this was truly the problem or not.
bluesy is offline   Reply With Quote
Old 05-09-2010, 09:56 AM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
How simple can it get????
My 84 month/100,000 Toyota Platinum Warranty:
Platinum protection covers virtually all component groups on new vehicles. If your new vehicle's component does not appear on our List of Excluded Components , it is covered by Platinum protection."
"List of Excluded Components
  • Accessory Drive Belts
  • Batteries
  • Body Panels
  • Brake Linings, Pads and Shoes
  • Bumpers
  • Carpet
  • Chrome
  • Clutch Friction Disk and Pressure Plate
  • Dash Cover and Pad
  • Door Trim, Handles and Fabric
  • Filters
  • Fluids
  • Glass (including Windshield)
  • Headliner
  • Heating Hoses, Lines and Tubes
  • Hinges
  • Hybrid System Main Relays
  • Hybrid Vehicle Battery
  • Hybrid Vehicle Battery Module/Pack
  • Hoses
  • Interior and Exterior Trim Moldings, including but not limited to, Cup Holders, Ashtrays, Covers, and Vents
  • Lamps
  • Light Bulbs
  • Nuts, Bolts, Clips, Retainers and Fasteners
  • Paint
  • Rotors and Drums
  • Rust and Corrosion Damage
  • Seat Covers
  • Service Plug
  • Shiny Metals
  • Spark Plugs
  • Structural Framework and Wells
  • Tires
  • Vacuum Hoses, Lines and Tubes
  • Weather Stripping
  • Wheels and Rims
  • Windshield Wiper Blades (Rubber Component)"
Old 05-09-2010, 08:40 PM   #4 (permalink)
2007 Camry SE V6
Gameroom cash: $133290
View thrawnis's Photo Gallery
Wow, thanks njerald. I have never seen such a concise list of the excluded items.
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 05-09-2010, 08:58 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
All he did was copy and paste from the Toyota page. The OP could have read the same thing without starting a new thread.
gdanaher is offline   Reply With Quote
Old 05-09-2010, 09:47 PM   #6 (permalink)
2007 Camry SE V6
Huh... I feel like an idiot.
Old 05-09-2010, 09:49 PM   #7 (permalink)
'07 XLE
Gen6
Right on.....
