2008 Camry audio harness color code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2010, 06:45 AM   #1 (permalink)
View merijn's Photo Gallery
I trying to find the color code for my 2008 Camry NAV ( NON JBL ) audio harness.
The only information i could find is for the older models ( before 2006 ).
As I would like to upgrade my audio system with new speakers and amplifiers but keeping the stock head unit.
I bought a new set of OEM head unit connectors ( 10 + 6 pin ) to connect the new cables to my OEM head unit without damaging the harness.
Are the color code the same as the old Camry’s ?
merijn is offline   Reply With Quote
Old 05-09-2010, 07:05 AM   #2 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
have U check http://www.camrystuff.com/ ?
have U check *** READ FIRST -- Official Gen 5 & 6 DIY and General Info Sticky! *** ?
workerant is offline   Reply With Quote
Old 05-09-2010, 07:15 AM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
go to camrystuff .com
The wiring for the connectors, will be found in the electrical wiring diagram manual, near the bottom. I may be mistaken, but I thought that the units with NAV were all JBL....
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 05-09-2010, 10:00 AM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
You missed where the OP was from....................
Old 05-09-2010, 10:06 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Correct.
The pin outs should be the same.....
Plus the moderators missed the:
Forum Rules
"16. There will be no posts or threads containing a direct link to Toyota Factory Service Manuals. All threads about any copyrighted Toyota material will be deleted. First offense will result in a warning, second a temporary ban, third a permanent ban."
MFG 02/25/2010
Stock, Shucks!
Old 05-09-2010, 02:48 PM   #6 (permalink)
^ rules are meant to be broken.
Old 05-10-2010, 12:36 AM   #7 (permalink)
Thanks all for the information.
I'm indeed from Thailand ( Dutchy ) but i believe that the coloring code should be the same as for other Camry's.
I found everything on Camrystuff, Great site i looks like i just found it on time
The other information here is only for the older models therefore my question in the first place.
I have only one more question.
What is the stock output power of the headunit without the JBL amplifier.
Thanks again for all the information.
Old 05-10-2010, 02:04 AM   #8 (permalink)
Twin & (1 of 8)
Luna2's Avatar
If you remove the amplifier, the output will be the input "line level" for the amplifier. It will be similar to trying to drive a speaker with only the microphone attached directly to the speaker and no amplifier. It just will not work as intended.....
MFG 02/25/2010
Stock, Shucks!
Old 05-10-2010, 02:43 AM   #9 (permalink)
I don't intent to connect the radio output to a amplifier line in.
I only try to check the need for a amplifier.
Maybe i only change the speakers when the output of the stock radio is high enough.
Other wise i will connect a amplifier to the line out of the radio is is there one.
Old 05-10-2010, 04:23 AM   #10 (permalink)
Twin & (1 of 8)
Luna2's Avatar
I do not know the details of the stock JBL amplifier or standard head unit power levels.
But if you want more drive to the speakers, add another amplifier for the Bass part of the system ( with a bass speaker in the trunk).
Check out the audio threads, lots of really good info there.....
Enjoy
MFG 02/25/2010
Stock, Shucks!
