2007 Camry I4 Clicking Noise @wheel in hard left turn - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2010, 10:08 AM   #1 (permalink)
View times1's Photo Gallery
Gen6 2007 Camry I4 Clicking Noise @wheel in hard left turn
When making a hard left turn a clicking noise is heard coming from the left front wheel area. Otherwise rides great! It's not repeatable when driving the same course, with same hard left turns? No visible damage to the CV joint or axle, no evidence of grease or damage to any components in the wheel assembly. Dealer wants $1200 for CV replacement, second mechanic found nothing wrong. Any ideas?
times1 is offline   Reply With Quote
Old 05-09-2010, 10:38 AM   #2 (permalink)
Silver 11 Camry le
Pujols85's Avatar
View Pujols85's Photo Gallery
if only when turns its the cv joint, just becuase the boot isnt broken doesnt mean the axle isnt. but 1200 is alot for just one axle!!!!
Pujols85 is offline   Reply With Quote
The Following User Says Thank You to Pujols85 For This Useful Post:
times1 (05-09-2010)
Old 05-09-2010, 11:05 AM   #3 (permalink)
Gameroom cash: $304255
It's probably the cv joint, but you usually hear the clicking sounds on the opposite side when making turns. That is, when making a left turn, the clicking should come from the right side, if that right cv joint is defective. As you make a left turn most of the weight is transferred to the right side. On a right turn the weight is transferred to the left side and that cv joint will click, if it is defective.
It should run around $250 to have a shop replace the entire axle, including the cv joint, with a reuilt one. That is the common method for replacing a defective cv joint today. That $1200 price is way out of line.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
times1 (05-09-2010)
Old 05-09-2010, 11:16 AM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Don't worry about the cost...just use your extended platinum warranty.
Old 05-09-2010, 11:51 AM   #5 (permalink)
View Cparise's Photo Gallery
I have same noise coming from right tire found a TSB online to replace intermediate shaft its been a big problem on these cars i ordered one waiting for it to be delivered. http://sumbiz03.home.comcast.net/~su...eringClunk.pdf
Cparise is online now   Reply With Quote
The Following User Says Thank You to Cparise For This Useful Post:
times1 (05-09-2010)
Old 05-09-2010, 08:51 PM   #6 (permalink)
TSB 07 Camry
Do you have other TSBs for 2007 Camry?
Old 05-09-2010, 09:29 PM   #7 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
It can either be CV joint or intermediate driveshaft. And listen to njerald and take advantage of the extra $$ you paid for your platinum warranty.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 05-10-2010, 10:35 AM   #8 (permalink)
Try this thread in our FAQ's for the gen 5 and 6 Camry:
TSB 2007 Camry Listing with PDFS!
Mike
