That's part of the ABS hydraulic module. When you get something like this it usually means something costly. For example, requiring the replacement of the entire ABS hydraulic module.
The solenoid activates to relieve brake pressure into the secondary circuit during operation.
However, the autoshop101s are old docs. I'm not sure if the newer ABS control modules used in Toyotas still use the same codes. For example, if it's a copy of the Teves or Bosch version 7 or 8 then it's quite a different setup. You'll get start-up assist (green light on a steep incline), electronic brake proportioning, acceleration slip control, emergency brake boost pre-charge, etc etc etc.
So again, I'm not sure if the codes are absolutely "backward" compatible.
I'd try removing and reinstalling the electrical connectors first. Maybe clean them with alcohol and allow to dry.
Originally Posted by clacker
Seems I didn't read the fault properly when I checked the front right wheel sensor and wiring
code 21 refers to the FR solenoid circuit in the "ABS control relay".
Anyone tell me where this is located?
Thanks
The Following User Says Thank You to JohnGD For This Useful Post:
When I turned the key with front speed sensors disconnected, I got errors 35,36 which ties up to that document so I think it is correct.
I have tried the connector cleaning; the light doesn't always come on now I have the wiring diagram, I can see what else I can find before having to take it to someone.
