Problem with driver's side door lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2010, 08:03 AM   #1 (permalink)
View dman81's Photo Gallery
I'm having a problem with my driver's side door lock. It's neither closing or opening while the remaining door locks work. Is this a fuse problem or is this going to require to disassemble the door? If so, where can I read more on this? Thanks!
2005 Toyota Camry LX
dman81 is offline   Reply With Quote
Old 05-12-2010, 09:39 AM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
First thing to do is check the fuse, and go from there.
Redline_Me is offline   Reply With Quote
Old 05-12-2010, 09:42 AM   #3 (permalink)
Schuy's Avatar
View Schuy's Photo Gallery
Chances are it is in the master switch in the drivers door or the lock motor itself if the rest work. The master switch comes out without door dissambly, the door lock requires the door panel to come off. If it was a fuse probaly none would work.
Schuy is offline   Reply With Quote
Old 05-12-2010, 12:27 PM   #4 (permalink)
I agree, can't be the fuse or all door locks would not function. So it might be the lock motor or master switch? You said the master switch does not require to remove the door panel... I think i might test there first before proceeding to the lock motor. What do you guys think?
