2007 Camry Japan Make - Remote Programming issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2010, 02:47 PM   #1 (permalink)
View ska07's Photo Gallery
Hello - I am having issues with adding a 3rd remote to a 2007 Camry (Made in Japan VIN starting with JTN..) The remote is 4 button HYQ12BBY, IC 1551A-12BBY (12BBY Denso). I tried the following steps from a posting here
open Driver door
within 5 sec Insert and Remove Key twice
open and close door twice < 40s
Insert and remove key once
open and close door twice and close door
insert key
STEP turn ON for 1s and then back to LOCK
STEP 1 time for ADD
STEP 2 times for REWRITE
STEP 3 times for CONFIRMATION and
STEP 5 times for PROHIBIT
The door lock should cycle if programming mode is entered.
However, the door lock does not cycle at all.
Previous owner had installed LoJack on this car and is still there with the FOBs for LoJack.
Any help is appreciated
Thanks TN!
ska07 is offline   Reply With Quote
Old 05-12-2010, 03:21 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
let the dealer do it for you. thats what i did when i bought my switchblade key for my 09 camry. i had them program it, costed like 45 dollars to program and cut the key.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
The Following User Says Thank You to BlackCam09 For This Useful Post:
ska07 (05-13-2010)
Old 05-12-2010, 04:03 PM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
The key can not be programmed by you. You need the dealer to do the job. The immobilizer must be programmed into the computer at the dealer.
gdanaher is offline   Reply With Quote
Old 05-12-2010, 07:17 PM   #4 (permalink)
View MstrToyoTech's Photo Gallery
first of all he wanted the remote programmed. second the immobilizer is an ecu in the car and the only thing that needs to be programmed to the immobilizer is the transponder code in the key. third the remote can be programmed through the body ecu in techstream. the door and key trick does not always work, especially if lowjack is wired to the doors and what not.
MstrToyoTech is offline   Reply With Quote
The Following User Says Thank You to MstrToyoTech For This Useful Post:
ska07 (05-13-2010)
Old 05-12-2010, 08:12 PM   #5 (permalink)
07 Camry Remote Programming issue
Thank you for all those responded. However, I am confused since there is a posting saying that Remote with Transponder chip could be programmed for Camry 07 in this forum. LoJack according to the previous owner is a becon device that responds only when activated by police when needed.
Again I don't have any further knowledge of how LoJack works. Getting rid of LoJack is a tough nut to crack. Otherwise I'll have to spend 100.00 to uninstall from the car through LoJack.
Thanks and hope that there is a Toyota Expert out there who would comment on this issue.
Cheers!
Old 05-12-2010, 10:09 PM   #6 (permalink)
First Toyo was '69 Corona
RickF's Avatar
View RickF's Photo Gallery
I don't see how having LoJack would interfere with the programming of your key - if in fact you can do that yourself. I've read in several places that this needs to be done by the dealer with a scanning tool.
LoJack is a passive device - only activated by the police. Or... if you have Early Warning (extra fob on keychain), and the car moves without the keys, the device will contact LoJack - who then will call you.
Also, LoJack usually wires the unit to the driver's power seat (always powered) - as it's close to where they like to hide it.
2005 Camry 2.4L
2AZ-FE I4 — 2009 Camry 2.4L 2AZ-FE I4
RickF is offline   Reply With Quote
The Following User Says Thank You to RickF For This Useful Post:
ska07 (05-13-2010)
