Go with NGK.
The
NGK Laser Iridium has a platinum ground pad. This reduces ground electrode wear so the plug can go 120K miles without replacement.
The
NGK Iridium IX does not have the platinum ground pad. It's usually good up to 60K miles.
Both should be more efficient than the older platinum or "regular" spark plugs. The IX should give you an edge because of the thinner center electrode (not noticeable under typical circumstances however). But price wise Laser Iridium is the better bet at about 41 more.
Check rockauto.com for prices.
Always verify application by using the spark plug manufacturer's catalog:
http://www.ngksparkplugs.com/part_fi...t.asp?mode=nml
Originally Posted by 5MTcamry
I am going to change spark plugs on my 2007 camry 2.4l. I was wondering, which is the best brand/model? I noticed NGK are popular, is " OE Laser Iridium" better or " Iridium IX"?
ANy other thoughts? My priority is fuel efficiency.
