Originally Posted by merijn
Youre right i'm planning to use two amps. ( one under the seat and one in the back ).
I think that this would be easier and also i could use shorter wires to the speakers and from the deck.
If i place both amps in the bacl i have to run inlet/outlet wires to the trunk for my door speakers.
As i do this for the tirst time all help is welcome.
I never used Kenwood before by they have to correct spec i was looking for but suggestions for other amps are welcome.
Just for youre info, i'm looking for high power inlet amps so i can use my stock wires as amp input wire. ( my HU does not have line out connections. )
Here is what you need to make it easier
a) Line Out Converter perferably a 4channel one or you can use 2 two channel ones
b) 9Wire otherwise known as speed cable (metra kicker scosche doesnt matter)
c) RCAs (get a good brand dont be cheap)
4channel line out converter
The line out converter turns your speaker wires in to rca inputs.
Pull your radio and find all 8 speaker wire colors. Leave about 3-4inches from plug to radio and cut wires. The half that is coming out of radio go to the wires coming out of the line out converter. white is left front, grey is right front, green is left rear and purple is right rear on converter.
The other side of the wire gets conected to the speed wire. It is also color coated the same, white, grey, green, and purple.
Speed Wire
You run the speed wire from the back of the radio to the amps out put connections and to the other side of the wires that you cut earlier behind the radio. Those wires are going to the factory speaker locations.
There is a blue wire in there also that you can use as the remote turn on wire, sometimes i do sometimes i dont
You can get this from a stereo shop or even best buy it usually like $30 for enough to do one car
RCAs
Get some good ones, moster would do perfect they keep alot of the noise out, more like all of it. They are shielded and oxgyn free. You will need two sets dont get ones for a 4channel install because you are doing two seperate amps you need two 2channel rcas.
You will run the power cable down one side from your battery to the trunk.
You will run the speed wire and rcas down the other side which includes the amp turn on wire
You will make a ground in the trunk, short as possible. Watch for gas tank when drilling. Make ground on floor of trunk or under rear passenger seat never on rear deck or side brackets.
This is how I would do it, but it also puts both amps in the trunk. You could make an amp rack out of mdf and cover with carpet or mount to back of rear seat
Again this is just my .02 cents. Ive been installing for 4yrs now but have been doing car audio for alot longer than that. But only MECP certified for 4 yrs so thats all I really count.
If you decide to do it this way and need more help I have no problem helping out all you have to do is email me or pm me and I would be glad to assist.
Good Luck
Bernie
