Yeah, I heard today's Toyota stated that 1.1qt/600 miles is considered "normal". That's just too bad and what a joke. They just don't build them like they used to.
In that case you might want to consider
Mobil-1 Emission System Protection (ESP) oils. These are really designed for diesel engines with exhaust side particulate filters. The engine oils will stay clean longer and dump less junk down the pipe so as to extend the life of the particulate filters. Better yet, these new oils are also approved for gasoline applications (not all diesel oils are).
Mobil 1 has two viscosities in the US, 5W-30 and 5W-40. The -30 meets
BMW LL-04 specification. These are very clean oils. If you can't find Mobil-1 ESP, then try BMW and ask for LL-04. (Always verify the viscosity range you need!)
If you need a thicker grade, the -40 meets
Mercedes specifications.
Mobil-1 ESP 5W-30:
http://www.mobil.com/USA-English/Lub...mula_5W-30.asp
Mobil-1 ESP 5W-40:
http://www.mobiloil.com/USA-English/...la_m_5w-40.pdf
Originally Posted by Scilane02
Thanks JohnGD.
There is no leak at all. It is mostly piston ring. I tried High Mileage oil like GTX and Valvoline MaxLife. They are even worse. It actually burns less than 1 QT per 1000 miles that is considered normal. Just want to find an oil that can burn clean in cylinder.
