02 Camry SE rear brake pads replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2010, 10:52 AM   #1 (permalink)
View renatog's Photo Gallery
I'm replacing the rear brake pads on my japanese made 2002 Toyota Camry SE. I'm having trouble trying to close the caliper (two "bolts" bold the caliper in place but the top bolt is not removable, so it pivots on that top bolt). It appears that the brake pads are too thick but that doesn't make sense. To my knowledge, that top bolt should allow the caliper to move side to side so that it compresses the pads to the rotor, but apparently it's not happening that way. I've already used a c-clamp to compress the caliper's piston and even tried compressing the top pivoting section to see if it might be stuck but it barely moves. The caliper is clips the outer pad by about a millimeter and won't close because of it. The inner pad has enough clearance though since the piston is compressed all the way in. The Haynes shop manual doesn't give any insight either.
Does anyone have any suggestions?
2002 Camry SE 130k+ mi.
2003 Honda CBR 600 RR
renatog is offline   Reply With Quote
Old 05-17-2010, 11:03 AM   #2 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
I have not seen your car's exact model but from the previous experience:
1. Make sure piston is flush with the caliper's body.
2. Caliper should freely slide on the pin, so wiggle it back and forth to get it properly sitted.
3. Make sure pads are sitting well: they should touch the rotor's surface and be parallel to it.
Good luck,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 05-17-2010, 11:11 AM   #3 (permalink)
It's all the way in, and as I said, that's not where the caliper is clipping, it's the outer pad area that is the problem.
That's what I think the problem is. It doesn't slide side to side, I had to mallet the damn thing open to even be able to get to the pads.
Yup, done that.
Good luck,
Sam
Thanks
Old 05-17-2010, 11:12 AM   #4 (permalink)
vvti-me's Avatar
View vvti-me's Photo Gallery
just as semy has said, follow those steps. i work on those all day at my work and i have an 03 se as well. you are correct about the bolts not coming out just make sure the pads sit in there well. if the pads are too thick you can sand them down i mean this by putting a piece of sand paper on the floor and giving it like four good rubs against it and perhaps itll make it easier. also make sure your rotors are not uneven. make sure they aren't too glazed as well. just take a little wiggling and umph to get them in there just make sure the piston is compressed and the pads are sitting in there really good.
p.s. if you decided to loosen the bleeder valve to make the piston easier to compress, be sure to bleed the brakes to have a solid brake pedal.
good luck!
vvti-me is offline   Reply With Quote
Old 05-17-2010, 11:20 AM   #5 (permalink)
2004 Camry LE
somick's Avatar
Thanks
I think you found the problem!
I would remove the caliper assembly from the top bolt. Clean it from rust. Lubricate.
Good luck,
Sam
1992 Subaru Loyale
Old 05-17-2010, 11:22 AM   #6 (permalink)
The caliper should move side to side, no? Is there a way to remove the caliper from the disc mount (not the entire caliper itself)? That pivot bolt is really tight and I can't see a way to remove it. I was able to rubber-mallet that thing open then after moving it quite a few times up and down it moved freely enough for me to remove the inner and outer pads.
Old 05-17-2010, 11:24 AM   #7 (permalink)
There is no top bolt! That's what's so frustrating, it just pivots on this 'top bolt' that isn't removable, or at least I don't think it is...
Old 05-17-2010, 11:34 AM   #8 (permalink)
2004 Camry LE
somick's Avatar
I have encountered the similar problem with my son’s Pilot’s rear brake. The slide pin is pressed into the brake bracket. And the bolt that holds the caliper is threaded into the pin.
There got to be a way to removing it!
Have you looked into FSM at www.camrystuff.com?
1992 Subaru Loyale
Old 05-17-2010, 01:43 PM   #9 (permalink)
Thanks Sam! That manual goes into way more detail than the Haynes manual. It doesn't say though how to remove the "Rear Disc Brake Bush Dust Boot"
Old 05-17-2010, 09:52 PM   #10 (permalink)
anyone know how or if I should remove this?
Old 05-18-2010, 03:31 PM   #11 (permalink)
Old 05-18-2010, 06:14 PM   #12 (permalink)
2004 Camry LE
somick's Avatar
I have been waiting for somebody who knows how to respond.....
Well, since this is just a boot, can you just pull it off?
1992 Subaru Loyale
Old 05-18-2010, 07:20 PM   #13 (permalink)
I dunno, I wouldn't want to do it without knowing if I need to replace it.
