Brake problems common on 2007 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2010, 01:56 PM   #1 (permalink)
View sdrone's Photo Gallery
I've got a 2007 Camry V6. Late last summer the brakes got noisy at around 40k miles. Some squealing, lots of other noise.
I cleaned 'em several times, greased 'em, etc. I could never get them to quiet down. The pads were not very worn. I finally gave in and got replacement pads. That fixed it.
Now it's less than a year and about 13k miles later. Brakes are getting noisy again. HOWEVER, I'm also sometimes getting vibration in the front end during braking. It doesn't happen around town, just on the expressway. It doesn't seem to happen unless I'm above 40mph, though if it starts above 40 mph it will continue as a drop below that speed. It often doesn't happen as soon as I hit the brakes, but it does seem to happen more if I'm having to use the brakes a lot. You feel the front end vibrate up through the steering wheel.
I'm trying to gather info before going out and replacing the discs and pads. I assume it could possibly be a warped rotor or pad.
are brake problems common on Camrys? The first 40k miles were fine, but now I seem to be fighting this issue off and on all the time.
sdrone is offline   Reply With Quote
Old 05-17-2010, 02:28 PM   #2 (permalink)
View TheWhiteGoose's Photo Gallery
I've got the same problem in my '08.
Brakes warranty after 36k?
Keep us updated. I'd be curious if just doing the fronts would solve the problem.
'08 Camry LE - White
'08 335i - Silver (www.n54tech.com)
TheWhiteGoose is offline   Reply With Quote
Old 05-17-2010, 02:49 PM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
The front rotors always warp on the Gen6 Camry. I had my first set re-surfaced twice and then I did a whole brake job. So far my second set has been re-surfaced once but the vibration is returning so probably by the end of the summer I'll have to do another full brake job.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-17-2010, 03:56 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
My brakes are quiet, not dusty and the original front pads are still there at 50,000 miles. Changed the rears at 46,000 and they still had 15,000-20,000 miles left on them.
My rotors have not warped and stop smooth but I always torque my wheel nuts when I change/rotate tires 2x/year.
Old 05-17-2010, 04:04 PM   #5 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
i just had my 09 camry front brakes replaced and rotors resurfaced under warranty. they said to come in before 36k so i can get my back ones done too. i have 29k on it now.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 05-17-2010, 05:10 PM   #6 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Well you're an exception on this forum for many reasons.
Rotor warping is a very common issue with the Gen6. A search will bring out a handful of other people with the same issue.
I think I read somewhere Toyota has since issued new part numbers but people with 2007 and 2008 (and possibly some 2009) cars tend to experience rotor warp sooner or later.
I've also had break squeaking a few times but it went away on its own.
Old 05-17-2010, 05:29 PM   #7 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
View ItsMeJon's Photo Gallery
I never had any problems when i had original pads, but when i switched to centric pads they squeaked like crazy. Now im on akebono so far no problems quiet and no dust. Ive heard they had tsb about squeaking brakes im sure if you haven't already do a search there's tons of stuff about brakes it seems pretty common.
Good Luck
ItsMeJon is offline   Reply With Quote
Old 05-17-2010, 05:31 PM   #8 (permalink)
molson.david's Avatar
Gameroom cash: $295153
View molson.david's Photo Gallery
I don't know if it's common or not problem,but I replaced rotors too,I got NAPA premium rotors and wagner ceramic pads on front.rear all stock.about 12k on them-so far so good.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 05-17-2010, 07:24 PM   #9 (permalink)
Good to hear you like the Napa. My plan for the rotor would be either Napa premium or Raybestos (sp?). For the pads, I'd probably just get Napa ceramics.
Old 05-17-2010, 07:57 PM   #10 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
My rotors warped at 23k, only b/c I used to have 20' rims.
Warping is a common problem as stated above. I would recommend upgrading rotors, they aren't that much more expensive than OEM.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 05-17-2010, 08:11 PM   #11 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
Same.. rotors warped around 25K...
Common... not common.. more like standard feature...
MJZ is offline   Reply With Quote
Old 05-17-2010, 08:13 PM   #12 (permalink)
View TAZCOOLS's Photo Gallery
have 65k + and have a little shake, no squeaking. plan to replace front pads at 70k, maybe rotors.
TAZCOOLS is offline   Reply With Quote
Old 05-17-2010, 08:27 PM   #13 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Toyota rotors have been having problems since 2002 Gen 5. They were replacing them free. There was a TSB for it.
I'm not sure if the brake system was under-designed or they were using cheap rotors and pads.
If you replace them I'd get Raybestos Advanced Technology rotors and Akebono ProAct ceramic pads. No Toyota rotors/pads. Check rockauto.com for prices.
The Following User Says Thank You to JohnGD For This Useful Post:
Yazovets (05-18-2010)
Old 05-17-2010, 08:46 PM   #14 (permalink)
Hello, Good Morning
ItsMeJon's Avatar
This man knows what hes talking about lol. Akebonos are awesome and I'm probably getting raybestos rotors next brake change.
Old 06-19-2010, 03:01 PM   #15 (permalink)
View SamB's Photo Gallery
Front end shaking during breaking
I had 35xxx miles on my 2007 xle v6 and went back to the dealer and they wouldnot do anything about it saying they did not cover "wear items" such as this. Does any one know if this is true, I thought 36000 mile coverage should do. With the 3 recalls and now warped rotors I don't think they should count on anymore business from me. I expected too much I guess.
SamB is offline   Reply With Quote
