2007 camry Audio Color Code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2010, 04:37 PM   #1 (permalink)
View NathanWjh07's Photo Gallery
I am having trouble with the rear speakers, i know the code is:
Left rear Speaker is Black/Positive and White/Negative
Right rear Speaker is Red/Positive and Yellow/Negative
But when i took out the rear speakers its both Black with a solid red line going all the way through and the other is black with red stripes
can you guys help me out to determine which one is which?
NathanWjh07 is offline   Reply With Quote
Old 05-19-2010, 06:44 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
The correct wiring should be:
Black Plus grouped with Yellow Neg Left Rear
Red plus grouped with white Neg Right rear
I returned your PM.
FYI, My 2011 don't match either.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 05-19-2010, 06:55 PM   #3 (permalink)
The way mine is grouped is, Black wit red line all the way through with black wit red stripes. Its on both pairs of speakers, but i see the correct colors coming out of the head unit, but at the rear speakers its no yellow or red or whit, just black with red
Old 05-20-2010, 02:54 AM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Connector OF1 is where it would change, which is located under the "A" pillar on the passenger side in the dash. Remove the glove box to gain access.
MFG 02/25/2010
Stock, Shucks!
Old 05-20-2010, 05:03 PM   #5 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
I'm guessing this is non-JBL?
My Partial Partout!!!
Photo Album
Old 05-21-2010, 05:22 PM   #6 (permalink)
Yea this is the non JbL
Old 05-21-2010, 06:11 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Connector OF1 is where it would change, which is located under the "A" pillar on the passenger side in the dash. Remove the glove box to gain access. Have you looked for the connector? It is just above the right side kick panel. should be the lowest right connector. Just match the wire colors to the pin number back to the head unit/receiver.
MFG 02/25/2010
Stock, Shucks!
The Following User Says Thank You to Luna2 For This Useful Post:
NathanWjh07 (05-22-2010)
Old 05-22-2010, 10:29 AM   #8 (permalink)
Thanks for the tip, i was going to try to trace it from the back all the way to the front
Old 05-22-2010, 04:10 PM   #9 (permalink)
View bluesy's Photo Gallery
Why not just hook them up and listen for the difference?
Perhaps I'm wrong on this, but its always worked for me before. Speakers should be loudest when you're in between them since you getting the noise from both equally. If they seem to get quieter when between them, one speaker is out of phase and you need to switch the polarity. I would imagine the same process would work for front to back to see if you have the phase wrong on the back in general, but I've only ever done this for left and right. This might be easier than tracing the wires though.
Either way, good luck!
bluesy is offline   Reply With Quote
