Dampening the road noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2010, 03:35 AM   #1 (permalink)
View Parasol's Photo Gallery
Ok, I have '07 Camry LE. The road noise is a bit much in this Camry.
I tried to seal it with weatherstripping (Home Depot), it's one of those rubber/foam black strip with a sticky side, I put it around the 2 rear doors, where the door hinges is attached to the body
The original weatherstripping there is loose, and if you move it around, the only thing that holds it together is a few clips. It doesn't seem to keep the wind from coming in. It's loose, and I can slide my fingers between the clips. This lets wind in, probably even make high pitch noise. Is there another product that I can use? Something that's real rubber, but more thicker and more dense than the OEM ones (that's around the perimeter of the door)?
I bought something like this:
Amazon Amazon
It helps alittle, but is still noisy. The OEM weatherstrips looks fine, no cracks or cuts, but it doesn't seem to provide enough noise dampening. I'm also probably looking into Dynamat, but that's for later.
Parasol is offline   Reply With Quote
Old 05-21-2010, 11:44 AM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Try quiet tires........
Old 05-21-2010, 11:47 AM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3630350
+1
If your tires are getting old they'll get louder. Consider low road noise transmission on your next set of tires, it can make a big difference.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 05-21-2010, 01:39 PM   #4 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
If you want to get really crazy with it, dynamat the interior flooring.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
