0W-20 or 5W-20 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2010, 05:42 PM   #1 (permalink)
View darkn355 r0lla's Photo Gallery
Gen6 0W-20 or 5W-20
I know the car booklet says 0w-20, but can you use 5w-20 till the rest of the car's life?
Will it damage the engine if i use 5w-20?
This is for the 2ar-fe engine
darkn355 r0lla is offline   Reply With Quote
Old 05-23-2010, 05:51 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
You are in SOCAL, I would stick with 5w-20. the 0w-20 is for colder climates..... Wrong answer.......
I stand corrected, 0w-20, located on page 489 of the owners manual.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 05-23-2010, 06:02 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
I don't have a 2010/2011 manual but the 2010 specs say:
"0w-20 is recommended. If 0W-20 is not available 5W20 may be used. However, it MUST be replaced with 0W-20 at the next oil change".
You can however, do anything you want.
Old 05-23-2010, 06:02 PM   #4 (permalink)
cool. but the funny thing is, the car booklet says, you can use 5w-20 but it has to be replaced with 0w-20 the next change.
why does it say that?
Old 05-23-2010, 06:10 PM   #5 (permalink)
'07 XLE
Gen6
Because that is what Toyota wrote.............
Old 05-23-2010, 08:27 PM   #6 (permalink)
'11 Camry
View JasonA's Photo Gallery
Wow. That was helpful.
The reason why they say that 5W-20 must be changed in 5,000 more miles is because 5W-20 is available in conventional oil as well as in synthetic oil. Toyota recommends the 10,000 mile oil change interval (OCI) when using 0W-20 oil only. You'll notice that the maintenance intervals are every 10k miles when using 0W-20 only, but they're every 5k miles for the V-6 engine and for the I-4 if not using the 0W-20 oil. Now, you COULD use synthetic 5W-20 and probably very safely run to 10k miles. But since 5W-20 oil is available in conventional, Toyota is recommending 5k mile OCIs for that grade, to be conservative.
If you want to run conventional oil, you could do it with 5W-20 no problem. If you're going to get synthetic 5W-20, you might as well get 0W-20, since you'll get a little better lubrication on cold starts (yes, even in SOCAL). However, not all synthetic oils are available in 0W-20 right now. If the synthetic oil you prefer is only in 5W-20, I'd run that for 10k miles.
The reason Toyota is pushing 0W-20 so hard is because they're required to. Why? The fuel economy data was developed with 0W-20 in the crankcase, and one of the requirements of that program is that the manfacturer has to do everything in its control to ensure that its customers use or have access to the same oil that was used during the fuel economy testing. In other words, the EPA wants to ensure that the customer has the opportunity to achieve the same fuel economy that the manufacturer did. So they can't put a super-thin 0W-10 oil in there or something like that and claim an elevated fuel economy number that most consumers could not achieve, because the oil is not widely available.
Bottom line: if you're using 5W-20 conventional, change it every 5k miles. If you're using 5W-20 or 0W-20 synthetic, change it every 10k miles.
JasonA is offline   Reply With Quote
Old 05-24-2010, 01:20 AM   #7 (permalink)
View TAZCOOLS's Photo Gallery
The only difference in 0 or 5 in the viscosity or pour-ablility of the oil. 20 is the effective weight of the oil at engine operating temperature. There is almost no difference in the 2. And too there reason its written like that in book is the engineers think customers are stupid. This is from a quote from a FORD engineer.
TAZCOOLS is offline   Reply With Quote
Old 05-25-2010, 11:10 AM   #8 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Very good discourse on crankcase oils. Thank you members.
Donald E. George is offline   Reply With Quote
Old 05-25-2010, 12:18 PM   #9 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
wow conventional is now changed at 5K miles? thats crazy.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 05-25-2010, 12:30 PM   #10 (permalink)
'07 XLE
Gen6
Nothing crazy about it. Dino Oils have improved dramatically in the last 10 years....
Old 05-25-2010, 12:40 PM   #11 (permalink)
씨발
interesting. Do you change every 5K njeezy? I change mine every 5K synthetic, and it still comes out black.
AdvanceSpeedShop
Old 05-25-2010, 01:05 PM   #12 (permalink)
'07 XLE
Gen6
Every 5,000 for me in all my vehicles.
Nothing wrong with black....the only way it won't change color is if you don't operate the engine. Your filter catches all the big particles.
Have a sample of your oil analyzed at your next oil change, it is probably fine.
I've seen hard working Ford p/u diesels on synthetic that at 9,000 miles the oil is still good by analysis readings.
Old 05-26-2010, 08:46 PM   #13 (permalink)
'11 Camry
This guy has near 10,000 miles on Chevron Supreme 5W-30 (conventional) on an '08 Chevy Impala:
http://www.bobistheoilguy.com/forums...92#Post1896292
And the analysis lab recommended extending his oil change another 2,000 miles based on the results.
Conventional oil, in addition to today's engine designs, make for MUCH longer OCIs (oil change intervals) than what most people do. Anything less than 5,000 miles with a good conventional oil in a relatively recent engine is usually a waste.
Remember that oil color is not an indication of oil condition. It's not a good indicator of anything, really.
Old 05-28-2010, 10:27 PM   #14 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
C'mon over and join us at Bobistheoilguy.com and check out our used oil analysis results. Oil color is largely meaningless in determining whether it's still protecting your engine. Diesels (yes, I know we aren't seeing many Toyota diesels nowadays...) and most of the new direct injection engines turn their oil BLACK almost immediately after it is installed. Anyway, the current crop of SM oils, even basic dinos, will do 5k without breaking a sweat. The soon-to-be released SN/GF-5 oils promise to do even better.
I do 5k right now ONLY to avoid the possibility of a warranty fight should the unthinkable happen. Once I go out of wty, I'll be doing 10k with an appropriate syn, without even losing a wink of sleep about it. And given the data I've seen, in most engines (unless you have one that's especially hard on oil), I'd do the same on any basic SM or SN oil.
2009 Camry Hybrid, Black.
2007 Avalon XLS, Cassis Pearl (that Burgundy color).
2004 Prius Package 9, Black.
ekpolk is offline   Reply With Quote
The Following User Says Thank You to ekpolk For This Useful Post:
PRINCESS PEACH (05-28-2010)
Old 05-28-2010, 10:29 PM   #15 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
I think it's a good idea so that you don't lose oil anyway.
MJZ is offline   Reply With Quote
