03 Throwing CEL. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2010, 11:05 AM   #1 (permalink)
Gameroom cash: $133200
View xx03Camryxx's Photo Gallery
Gen5 03 Throwing CEL.
Alright, the first time the CEL came on I told my dad about it and he said it probably was just the exhaust. So after a week or two it went away. Then I went snowboarding and on the trip home it came up again. It didn't really bug me that much because the car was running fine. It went away after a week or two. Now, today it turns on yet again. I'm beginning to think this is a problem I should fix...but what's the usual scenario for this? Or do I have to get a scanner that can tell me the code? lol
Thanks.
xx03Camryxx is offline   Reply With Quote
Old 06-01-2010, 12:21 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
you will need a scanner to tell you the code.
LoudCamry is offline   Reply With Quote
Old 06-01-2010, 12:29 PM   #3 (permalink)
First Toyo was '69 Corona
RickF's Avatar
View RickF's Photo Gallery
Yep, you need a scanner to tell what exactly is wrong. It could be something as simple as not tightening the gas cap good enough at your last fill up - which is something my mother-in-law (age 85) has done a few times.
2005 Camry 2.4L
2AZ-FE I4 — 2009 Camry 2.4L 2AZ-FE I4
RickF is offline   Reply With Quote
Old 06-01-2010, 01:29 PM   #4 (permalink)
Damn, you guys know if I can pick this up at Autozone or pep boys?
Old 06-02-2010, 02:47 PM   #5 (permalink)
Lol so I went to Autozone and got the code.
P0420..I'm thinkin the cat is bad.
Old 06-02-2010, 03:02 PM   #6 (permalink)
RickF's Avatar
You might be in luck if you have less than 80K miles. The Cat and ECU are covered under the 8 years/80,000 miles federal emissions warranty.
See this discussion for some possible alternatives if over 80K:
Secret extended warranty for Catalytic Converter???
2005 Camry 2.4L
Old 06-02-2010, 03:07 PM   #7 (permalink)
Lol the car is at 135k. I'm not willing to drive all the way down to California for this...I do however have good ties with a Meinike here in vegas. I'll probably be buying an aftermarket cat and muffler. Was planning on getting the muffler anyways. Thanks
Old 06-02-2010, 03:26 PM   #8 (permalink)
RickF's Avatar
You're welcome.
BTW, my wife's '05 Camry had to have the Cat replaced last year for the same code. Thankfully it was under warranty with 48K miles. Can't believe the Cat failed that fast. I made sure they ran diagnostics to be sure the car wasn't running too rich (something that can cause the Cat to burn out prematurely).
Hope you get a good deal with Meinike.
2005 Camry 2.4L
Old 06-02-2010, 03:36 PM   #9 (permalink)
Ah yeah thankfully you had the warranty.
Well, I called them up they said if they buy the cat it will be warrantied under the shop. OR I just buy an aftermarket catback w/o warranty. Decisions decisions....
Old 06-03-2010, 01:17 PM   #10 (permalink)
Well, they want $1k to replace the cat.
Old 06-03-2010, 09:40 PM   #11 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
thats not the cat btw. it's under the car. get a high flo cat and custom piping while u at it.
WrongFitmentCrew#628
Old 06-03-2010, 09:57 PM   #12 (permalink)
Lol after 2+ hours reading it is the cat bro. Toyota put the cat in the exhaust manifold. There is an o2 sensor below that. There are two cats one in the front and one at the end.
Old 06-03-2010, 09:57 PM   #13 (permalink)
View camryen08's Photo Gallery
My 08 LE got CEL on yesterday. autozone in california don't do it for free any more. I will borrow a scanner from my friend this saturday to pull the code.
other than too rich, is there any other reason may causes p0420 or Cat fail?
And will it causes any damage to other parts if i do not replace it immediately?
Thanks.
camryen08 is offline   Reply With Quote
Old 06-03-2010, 10:04 PM   #14 (permalink)
Thanks.
Yeah, your o2 sensors might be sluggish. There's a whole lot of problems with this code. There is no real solution. I read about someone changing both cats and all the sensors and there was still a problem. Cost him 1800 bucks. There is no real solution, but start cheap. You can get a anti-fouler and try that. It makes it so the o2 sensor isn't as hot and keeps it cool and the it wont throw a CEL.
The Following User Says Thank You to xx03Camryxx For This Useful Post:
camryen08 (06-03-2010)
Old 06-03-2010, 10:06 PM   #15 (permalink)
You mean gen5/gen6 has two cats, or two O2 sensor, or both?
When people say replace cat, do they replace O2 sensor together?
Or O2 sensor could be still ok, and no need to replace?
did 1k includes O2 sensor?
Sorry for ask so many question one time
