Can't really tell from the picture if it's just the imprint (depressed) by the raised part of the pan. (There are gaskets with raised bead all around). I think that's what it is an imprint from the pan, so when you take off the aftermarket gasket you should see the same.
I'd get a Fram ATF kit. They typically come with cork-rubber gaskets (a composite gasket). Did you change out the felt filter that can plug up over time?
What type of ATF are you using, Toyota's dino Mobil-3309, relabeled as T-IV? Or a synthetic blend like the Castrol Import Multi-vehicle ATF suitable for D-III and T-IV?
Originally Posted by olympicgold
Ok if you look at this OEM gasket you can see indentation in the gasket. On all aftermarket gaskets there is no such indentation and they are absolutely flat.
Share your thoughts
