Does anyone know for sure if the TPMS sensors in the OEM steel wheels will work with the OEM alloy wheels. I've seen some references that the sensors are different for the steel vs. alloy wheels. But when I look up a part number, it looks like there's just one sensor part number. So I'm confused. Hopefully, someone here has some direct experience with that.
I'm planning on upgrading to the 7-spoke 16" alloys from a Camry, and if I can use my OEM TPMS sensors, that'd obviously make the switch much cheaper.
Thanks.
Not too much hope if you answered you own question and then still don't know.......
Your reply really wasn't helpful at all. I'm not sure why you wasted your time replying if you weren't going to say anything useful.
I have conflicting information. If you know the answer, I'd thank you for sharing it with me. If you don't know the answer, you can save your nonsensical reply.
He meant they are the same since there's only 1 part number as you found. When I changed to different wheels, the TPMS were safely moved to the new wheels. I think the tire pressure is like before, 32 (don't have to change anything in the ECU).
I just wonder that some tires are recommended to use higher pressure, while the manual says it should be 32. I think I have to follow the manual, right?
Thank you for your answer! You moved your TPMS sensors from steel wheels to alloys?
If he meant to say that they're the same, it would have been helpful for him to just say that, instead of trying to joke someone who's simply looking for an answer.
Yup, I moved the sensors from steel wheels to alloys. Later, I changed to the TRD wheels, and the sensors were moved to these wheels. They work the same as before.
For what it's worth, this is the conflicting piece of info that I read, from Tire Rack:
Only OE TPMS sensors from OE alloy wheels will fit in the alloy wheels we sell. Sensors from OE steel wheels will not work in alloy wheels. The OE alloy wheel TPMS sensors are available for purchase from us. The QUICKSET is not compatible with the 2010 model. New tire sensors must be initialized at the vehicle's dealership. This charge is not included in the cost of the sensors. If TPMS sensors are not installed in the wheels, the TPMS light will flash for 1 to 2 minutes and then stay permanently illuminated. An audible chime may also be heard at start-up.
If OE TPMS sensors from OE alloy wheels somehow fit differently than TMPS sensors from OE steel wheels, that lead me to believe that they're different.
Well, there's your problem. You are reading something from a third party tire and wheel vendor with a generic comment that applies to all manufacturers. Not a single word here about Toyota. When in doubt, call and talk to a real person rather than relying on the legaleze that was generated to cover all situations. Call Tire Rack and/or Toyota
I remember someone said that for some wheels, the angle of valves may be different. Is it the case?
My dealer just moved the TPMS from steel wheels to the alloy wheels, so I think our Camry's valves can be used for different wheels.
ebumdude and tengiday, thank you, thank you, thank you!
No problem.
I have switched mine out a total of three times. Once from steelies, then from alloy to alloy. They work the same and are good to go since the day I bought the vehicle.
Don't be persuaded by a 3rd party source who is out to make an extra buck.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
Right you can switch all you want as long as sensors aren't impeded by rims. The one thing you can't do is have 2 sets of sensors. ie one on winter set and one one summer.
