Originally Posted by Bub1958
Thanks for the replies. The TF is new, timing belt, drive belts and water pump were replaced t 90K, new radiator in 2005 (front end damage), fuel induction system service in '07 along with a new battery. Brakes and rotors are new, although they've been replaced 3 times! Fuel pump and fuel filter are probably original.....don't know if the pump normally becomes problematic at this mileage.
Seems like a bulk of the things were already done. There could be a lot of small things you could do I suppose; as already mentioned. But I don't think fuel pump is really an issue.
1) Fluids (Just make sure 'all fluids', even brake fluid (importantly) are fresh and done properly.
2) Typical plugs gapped and torqued correctly.
3) All types of hoses should be inspected and replaced.
4) Typical filters. Oil, Air, Fuel
You could check out the sensors, and even gas requirements. Make sure she is using premium on the v6 (i suppose).
I would get better brake pads perhaps if that's the case. Although I can see your emphasis on the brakes being replaced often. LOL
Check to make sure there is no oil leaking into the spark plug tubes.
But if possible, see if there is a phone service that would extend to that area of coverage.
Good luck.
