Camry LE V6 2008 Fuse Box, power outlet and CIG - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 09:05 PM   #1 (permalink)
View Dzorm's Photo Gallery
Gen6 Camry LE V6 2008 Fuse Box, power outlet and CIG
Hi,
I did a test in my camry... The two 12v socket (one in the front and the one beside the conductor) is on the 20amp Power Outlet FUSE.....
I want to know what is on the 20amp CIG fuse.... I didn't find anything yet for the moment.....
I want to know this because i plan vacation... i have to plug GPS, 12v cooler, etc... i wanted to split the power between the two socket but they are on the same fuse... so now i try to find where is the CIG Socket....
if someone know can you tell me!
Sorry if my english is not so good, i'ts my second language.
Thank you
Dzorm is offline   Reply With Quote
Old 06-26-2010, 03:06 AM   #2 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
Im not really sure what your asking, you can probably find that fuse in the fuse box under the dash. if your just using those two things thats going to plug into cig outlets, i doubt your going to use more than 120watts which is the safe zone that is stated on the inside of the cig cover.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 06-26-2010, 04:25 AM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $455050
View Luna2's Photo Gallery
Originally Posted by Dzorm View Post
Hi,
Thank you
Get a fuse tap and extend it to the cooler. The CIG fuse position isn't used on the Gen 6, it's a carry over from the Gen 5. Gen 6 prints don't indicate any wired connection to that fuse slot outside of the fuse holders.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 06-26-2010, 10:52 AM   #4 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Your Engish is alright Dzorm. Regards
Donald E. George is offline   Reply With Quote
Old 06-26-2010, 03:31 PM   #5 (permalink)
Thank you Luna2!
well i hope next time toyota will put each socket on each fuse so the owner will have more power for their equipement!
have a nice day!
Old 06-29-2010, 12:31 PM   #6 (permalink)
well, i talked to a tech a my toyota dealer.... they can't put anything on the CIG Fuse.... They already try to put equipment on it and make more trouble....
i don't know how to say exactly in english... but apparently that fuse is like a security for other thing.....
The solution is to get a new circuit directly from the battery with a separte fuse out of the fusebox of the camry....
I will try to do it myself... it will cost less then toyota charge for this!
Have a nice day!
Old 06-29-2010, 06:39 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Have a nice day!
It may be that the person who tested the "CIG" fuse pulled the wrong one which could have been the ECU-ACC fuse, above the "CIG" fuse. The ECU-ACC fuse pulled would cause the security issue and several other electrical problems you described.
MFG 02/25/2010
Stock, Shucks!
