hello,back again,after all the search ,the dealer wanted 500 dollars to replase one sensor,i jacked up the car,located all the four sensors,sprayed all with lub oil,then ordered 4 sensors denso parts for 350,bought sensor socket and have already flexible head wrench,night before jacked up the car and sprayed all sensors again,in the morning took all the sensors out ,very easy to break the factory torque,put new sensors and car driving as smooth as you can imagine in only one our,,,just be up to the chalange if you want
By the way,both B1S1 and B2S1 are the same but different cable length ,the same for the other 2 sensors
