Originally Posted by gdanaher
Well it's been awhile and you haven't had any response so I will give it an outside shot. I don't have a manual for that year but the Gen6 usies the odb to collect those codes and there is some discussion of it in the later service manual. At this point I would see if the local parts store would pull the code for you and then you can research it from that angle. How many miles on the car? If the pedal is spongie and there are no leaks at the wheel cylinders, then the master cylinder might be suspect and need to be rebuilt/replaced.
Thanks for your reply. Local parts store (Autozone, Advance) only reads engine DTC's but not ABS codes.
Also the harness in the above link (
http://codes.rennacs.com/plugins/Toy...16-Sequoia.php) is on older model Toyota's and Lexus. My 02 doesnt have it but my 90 Lexus does.
I'll ask the parts store if I can buy the Actron ABS scan tool and then return it for full refund.
