DIY:LED power folding mirrors w/ JDM OEM switch assembly on Gen6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2010, 09:10 PM   #1 (permalink)
bleachigo's Avatar
Gameroom cash: $244505
View bleachigo's Photo Gallery
So finally had the time to take some pics and redo my LED power folding mirrors with the JDM switch.Hopefully this will end all the questions about this particular mod for the Gen6 Camry.So here you guys go and hopefully it helps everyone.
PARTS NEEDED:
wire hanger
twist-on wire connectors
22-24 gauge wires
driver's side:5-6ft of wire for LED function and power fold function(x4)
passenger's side:8-10ft of wire for LED and power fold function(x4)
molex connectors(male & female)
molex pins(male & female)
This is where i got my LED power folding heated mirrors from so there might be differences with some other sellers.When i got mine,they did not offer the contol module that they are selling for $38.It is probably for auto folding when you lock and unlock the car with the alarm.You will not need it if you use the JDM switch as you can fold and unfold anytime with this switch.
http://www.autosignalparts.com/toyot...or-sae-rh.html
This is where i got the OEM JDM switch:
http://www.rhdjapan.com/toyota-oem-o...-62980?nflag=1
remove door panel
After removing door panels,take out your old mirror assembly and put in the new one.Then do this:
Next we will need to modify the mirror switch panel a little in order for the JDM switch to fit as it is shaped a little differently since it is was made for RHD Camry and also it has a notch in the middle instead of the left.You don't really need to do the next two pics but i just wanted to show the notch more clearly.When you make the new notch on the panel though,make sure to not cut too much so the switch assembly will not be loose.Cut a little and then test fit each time.
Now we can do the wiring.First cut the necessary wires to their length and snake them through with a wire hanger so you won't have a hard time later.Four wires on each door.2 wires for LED signal and 2 wires for power fold function.
For reference,this is how the USDM driver side connector looks like
This is the connector that came from the LED mirrors
Can't connect them so i had to make my own connectors like this.Test to see all functions of the mirror adjust works and if you have heated mirror option,test it also.
For the LED signal,tap into the wiring by the driver's side door sill.This is a little tricky as some of them have the same colors on the wires.As you can see from the pics,i made a couple of mistakes too.This might change also with the 2008-2011 Camry but for the 2007 Camry that i have,the yellow with silver stripes is for the drivers side turn signal and the green with silver stripes is for the passenger side turn signal.From what i notice though,the wires were at the top of the pile instead of the bottom but you'll never know.Proceed with caution.Test to make sure they work.
Now for the power fold connection.We are going to need a different kind of molex pins than what we used on the other ones.If you can hunt down the exact same pins that Toyota used,then your all set.If not,then you have to get the best fitting ones for the connector.You can see from the pic that the one i used are a little bigger and i had to push them each time when i connect the connector to the mirror switch assembly because they get pushed out.As a result, i can't put the plastic cover that i took off from the first pic since the pins were bigger.
Finally,videos of the folding and LED function.
07 red XLE V6,SE grille,Megan coils,Nokya 7K Arctic White fogs,LED int.& ext.,pwrfolding,heated turn sgnl mirrors,5k HID,UR sb&rsb,LED door handles,25% tint,Sprtwing roof splr,JDM lic.plate hldr,JDM sidemarker,JDM mirror switch,AVS slim visors,ass shave,F5 CAI,cut shifter
bleachigo is offline   Reply With Quote
The Following 4 Users Say Thank You to bleachigo For This Useful Post:
a_tov29 (03-31-2011), EddieVVTI (11-08-2011), streetuner (07-08-2010), workerant (07-06-2010)
Old 07-06-2010, 09:18 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $528010
View BlackCam09's Photo Gallery
nice diy bro, looks like alot of work. lol
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is online now   Reply With Quote
Old 07-06-2010, 09:28 PM   #3 (permalink)
bleachigo's Avatar
Thanks.I've had it wired up for a long time with a momentary switch but not with the JDM switch.So mostly today was just taking pics and removing panels.
Old 07-06-2010, 09:42 PM   #4 (permalink)
gabypr's Avatar
Gameroom cash: $112500
View gabypr's Photo Gallery
wow nice job and nice instructions. grats on your folding mirrors, its a nice touch to have and gives your car a unique feature.
My domain: http://www.cardomain.com/ride/3273187
Straight from my beautiful island Puerto Rico
gabypr is offline   Reply With Quote
Old 07-06-2010, 09:54 PM   #5 (permalink)
gabypr's Avatar
i forgot to say that if you could make a video showing your car from outside closing the folding mirrors would be great. again thanks
Old 07-06-2010, 09:54 PM   #6 (permalink)
Gameroom cash: $418500
View tengiday's Photo Gallery
Nice write-up, detailed instruction!
I will choose this if the mirrors are the same to our OEM mirrors: flat, convex, and "Objects in mirrors are...". I wish Muth mirrors have the signal on the cover of the mirrors like this one, not the in-glass signal.
tengiday is offline   Reply With Quote
Old 07-06-2010, 09:57 PM   #7 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Very nicely done. As a suggestion, for some of the pictures, the black text is hard to read on some images. If possible, redo it with white text
CarDomain
Old 07-06-2010, 10:00 PM   #8 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
real nice write up. i'll prob get to this towards end of the year.
WrongFitmentCrew#628
Old 07-06-2010, 10:16 PM   #9 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Originally Posted by bleachigo View Post
http://i272.photobucket.com/albums/jj181/hardogei/116.jpg
Alternative way is to just pop the rubber piece out from both sides and then squish it down until it's straight and a few inches long. Then you can feed wire in much easier.
It may be necessary to disconnect those wiring harness from the inside. I don't remember exactly. It's been a while since I've done the disassembly.
2007 Camry 2.4L 5M
Old 07-06-2010, 10:20 PM   #10 (permalink)
bleachigo's Avatar
Put it up for you.Look back to the first post.
Old 07-06-2010, 10:26 PM   #11 (permalink)
bleachigo's Avatar
Which particular pics are you having a hard time reading?
Old 07-07-2010, 12:11 AM   #12 (permalink)
eighty5iv's Avatar
Gameroom cash: $296110
View eighty5iv's Photo Gallery
Do you happen to know if the outer cover of the switch comes in black? I know for many SE owners who have that portion of their dash in black may also like to know. I browsed around and it seems like it didn't have it.
eighty5iv is online now   Reply With Quote
Old 07-07-2010, 12:21 AM   #13 (permalink)
Registered User
Gameroom cash: $161900
View hientham's Photo Gallery
nice!
hientham is offline   Reply With Quote
Old 07-07-2010, 12:36 AM   #14 (permalink)
bleachigo's Avatar
Anyone correct me but i don't think Japan has an SE version.I'm not sure either what the japanese Camry interior choices are but it might be harder to get it at a different color.Contact rhdjapan.com to confirm.
Old 07-07-2010, 01:02 AM   #15 (permalink)
eighty5iv's Avatar
will do. but if not I wonder if we can do something like this?
http://www.yarisworld.com/forums/sho...interior+parts
