So you have a down stream sensor but it is apparently malfunctioning? Or there is a sensor there but not attached to anything? The sensor is normally attached to two wires and puts resistance on the circuit based upon what the sensor thinks of the air flow. You could try jumping the wire with a half watt resistor of some value--it will vary, and see if the computer can be tricked. For starters, measure the resistance across the sensor and see if you can match it if the sensor is not installed. Hope this helps a bit because I'm not sure I fully understood the initial question.
