spark plug recommendations? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2010, 08:10 AM   #1 (permalink)
View fondoo's Photo Gallery
my 2003 camry is getting close to 100K miles now and what spark plugs do you recommend? should i just buy toyota dealer spark plugs? are they easy to replace?
fondoo is offline   Reply With Quote
Old 07-09-2010, 08:26 AM   #2 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
NGK that fit your engine, not sure if you have a 4 cyl or 6cyl
Platinum would work, I would go with Iridium myself.
4cyl
NGK Part # 2978 {Premium Platinum #BKR6EP11}
DOHC {.044 gap}
NGK Part # 4589 {Premium Iridium #IFR6T11}
DOHC {.044 gap}
6 cyl
DOHC {.044 gap}
Updated model - but the old part numbers I had up there would work just fine
Here is the chart to look them up yourself
http://www.ngksparkplugs.com/part_fi...t.asp?mode=nml
kenny1773 is offline   Reply With Quote
Old 07-09-2010, 09:09 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The stock plugs in the I4 are NGK Laser Iridium or Denso Long Life Iridium and should have longer life than the IX Iridium and GP Platinum.
The stock plugs have platinum or iridium chips on both the center and side electrodes; kenny's recommendations do not.
2007 Camry 2.4L 5M
Old 07-09-2010, 09:32 AM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Assuming you have an I4 engine, they are easy to get to. Pull the plug wire cap off one plug, use a 5/8 (I think) deep well plug socket, a 6 inch extension, and a ratchet. Pull one plug out, jot down the number, and replace until you get a new set. Do this when the engine is cold, and it doesn't hurt to put a drop of light oil on the plug thread before reinstalling so that it goes in easily and doesn't booger the threads.
gdanaher is offline   Reply With Quote
Old 07-09-2010, 12:13 PM   #5 (permalink)
First Toyo was '69 Corona
RickF's Avatar
View RickF's Photo Gallery
I second the recommendation for NGK Laser Iridium.
2005 Camry 2.4L
2AZ-FE I4 — 2009 Camry 2.4L 2AZ-FE I4
RickF is offline   Reply With Quote
Old 07-09-2010, 12:27 PM   #6 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
Just get stock spark plug, it last 100k
LoudCamry is offline   Reply With Quote
Old 07-09-2010, 03:53 PM   #7 (permalink)
Depends on price, there is no reason to pay the toyota markup for plugs, toyota doesn't make plugs so the NGK is the same plug for possibly less money depending on your dealer pricing.
rockauto.com sells the NGK Part # 4589 for $6.80 each + shipping. My local toyota dealer is a theif and charges OVER msrp for parts like this. So there might be a reason not to buy them from a Toyota dealer directly YMMV
Old 07-15-2010, 07:58 AM   #8 (permalink)
View NathanWjh07's Photo Gallery
What about the 07 i4 camrys? what plugs do you recommend for those, im reaching my 60k mark and need to get a tune up done
NathanWjh07 is offline   Reply With Quote
Old 07-15-2010, 09:26 AM   #9 (permalink)
Frugal Modder
hariaum's Avatar
View hariaum's Photo Gallery
Same plugs as the 03. You have the same 2AZ-FE engine. From my experience the best plugs are the NGK Laser Iridium.
hariaum is offline   Reply With Quote
Old 07-15-2010, 10:44 AM   #10 (permalink)
Leave them alone. The maintenance interval 120 thousand miles.
The plugs have platinum chip on the side and iridium chip/ring on the center electrodes. This makes the service life longer by detering electrode erosion.
At 60k, the only thing I'd do is change the two air filters and optionally drain and refill transmission and radiator. Do not flush the cooling system since you can only buy the Toyota coolant in diluted form. If you change to something like Peak Global coolant, that is different though.
2007 Camry 2.4L 5M
Old 07-15-2010, 06:16 PM   #11 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Lightbulb
Sorry, close but no cigar. The 2.4 liter starting in 2002 has a coil on plug design. Start by taking off the top engine cover. Working on 1 cylinder at a time, remove the wire connector from the coil and the bolt holding the coil to the valve cover. Pull coil straight up and off. From there its just a simple matter to remove and replace the plug. Do not touch the gap on Iridium plugs, they are factory set and do not need to be adjusted. NGK or Denso plugs would be the only two brands I would even consider putting in a Toyota. While you have the top engine cover off I would replace the pcv valve. It screws into the rear half of the valve cover on the passengers side. Good luck to you sir.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
