I just completed installing an aftermarket JVC radio in my 2003 XLE which utilizes the factory JBL amplifier. It sounds nice when incorporating the amp so I figured I'd post this tip about the wiring harness adapter I used for the installation. It's a Metra 70-8113 designed to be used with the factory amp. It worked great except it was missing a wire to connect the radio illumination wire to the factory harness. However, I found a workaround which allowed me to avoid cutting into the factory wiring.
In the photos, you'll notice a solid blue wire on the Metra harness which was originally marked "Power Antenna". After locating the correct "Illumination" wire (dark green) on the factory harness, I identified the corresponding pin location on the Metra harness (which was empty). After a few minutes of tedious work, I was able to carefully remove the solid blue power antenna wire and relocate it to the new "Illumination" location.
After that, plugged everything in and completed the install. Everything from amplifier turn-on to dimming with headlight functionality works great (not to mention the awesome sound when comparing to the factory head unit!). I should note that I used the four RCA connectors on the Metra harness to plug into the aftermarket head unit (RF/RR/LF/LR) RCA outputs. Very happy with the install so I hope this tip helps someone else who is thinking about a gen5 camry head unit swap.
