DIY: 2AZ-FE Water Pump and Belt Replacment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 04:50 PM   #1 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Lightbulb DIY: 2.4L 4cly (2AZ-FE) Water Pump and Drive Belt Replacement (Many Pictures)
This is my first DIY so any comments to improve the procedure will be gratefully received. I want to thank all the TN for posting their own DIYs and it’s my turn to give something back to the community.
I completed this procedure at 156,000 miles on my grandmother's 2002 Camry 2.4L (2AZ-FE Engine). It still has the original water pump but the belt had been change six years ago. Even though it wasn’t losing too much coolant, it's still a good idea to change it before the pump fails.
Applications
2002–2009 Toyota Camry
2009– Toyota Matrix
2009–2010 Pontiac Vibe
2009– Toyota Corolla
2002–2009 Toyota Solara
2004–2008 Toyota RAV4
2001–2008 Toyota Highlander
2005– Scion tC
2008– Scion xB
I may have miss some vechiles.
Disclaimer
Use this guide at your own risk. I nor TN assume no responsibility for any damage to your vehicle or personal injury as a result of following this guide.
Basic tools
Ratchet and socket set (3/8 and ¼)
Clean drain pan
Lug nut wrench
Jack and jack stand
Pliers
Funnel
Level 2 tools (Optional but recommend)
Torque wrench (in and foot lb)
C-cramp
Degreaser
Fender cover
Special Tools (Optional)
Pin Wrench (09960–10010) there’s an alternative way.
Serpentine tensioner tool (09249–63010) Didn't work for me.
Time Required
It took me 6 hours from start to finish, including time to take photos, and lunch. But it took me another hour to clean up. I think it could be done in about 3 hour.
Parts Needed
a) Water pump (In this case, Duralast) $55
b) Serpentine belt $20 (I find Gates and Master Pro to be better belts, and OEM)
c) Gasket sealant, RTV
d) A Gallon of Coolant $10
Let’s Start
Pull your vehicle into your favorite work area. I highly recommend disconnecting the battery but this Camry will forget how to idle, and I didn’t want to reset it. It’s a problem on most 2002-2004 Camry 4 cly.
Here, you can see the water pump leaking, located underneath the alternator.
Take advantage to loosen the 4 water pump pulley bolts (10mm) now with the belt on. (pic shown without belt) The belt will hold the pulley from turning. If you forget like I did, there will be alternative way later.
To remove the belt, the tensioner must be push down. There an area to put a ratchet onto and push forward and down. (orange arrow)
I tried the Autozone serpentine tool but there’s not enough room. So a 15 mm (I think, test fit a few socket) and a 3/8 ratchet with a pipe works, then slide off the belt.
Here’s the belt route drawn ouut.
Next, loosen and remove the two alternator bolts (green arrows), unplug the wires and remove the alternator.
If you left the battery connect, tape up the main changing lead to prevent shocks (red arrow). And remove the alternator from the engine.
Next, drain the coolant. There’s a drain plug at the bottom of the radiator (blue arrow). Unscrew it and will begin to drain, removing the radiator cap helps it drain faster.
Here is how I loosen the bolt with the belt off. I took the old belt and wrap it around the pull and cramp it down, it will substitute as Toyota’s pin wrench tool. Then with a 10mm wrench, remove the 4 bolts.
Remove the pulley from the pump. Now remove the 6 nuts and bolt around the pump. A ¼ drive set helps here.
Now the pump is loose, but the crankshaft position wire was still attached to the pump. It could be remove by pushing the pin out (yellow arrow) with pilers from behind.
It is optional to clean the crankshaft position sensor. To help route the new belt, set the parking brakes, jack up the front right, and when on a jack stand, remove the wheel.
Remove the two 10 mm bolts (orange arrow) that hold the splash shield in place.
Remove the 10 mm bolt that holds the crankshaft position sensor in. It will slide out, be careful not to rip the o-ring or wire. Replace if needed.
Back to the water pump. With everything out, you can see where the clip slide into the water pump hosing (violet arrow) remove it with a pliers if you haven't done so.
Compare the old to the new to be sure you have the correct replacement pump.
Degrease the side of the block; clean the position sensor area to with a rag (yellow arrow). Clean the sensor itself, there was some metal shavings on it. It’s a magnet.
Coat the new pump and clean block with the RTV. The new pump came with a paper gasket and I decided to use it.
As you bolt the pump on, there’s only two choice, bolts or nut. You can't mix it up. Torque them to 80 INCH lb.
Again that INCH, Not FOOT lb. A torque wrench is hard to get in there so guess with a ¼ drive ratchet. Remember to attach the metal retainers first (red arrows) as you install the bolt and nut. Push the plastic clip (blue arrow) back onto the water pump.
Oil up the sensor’s o-ring and side it into the block. Install the 10mm bolt.
The alternator has a metal sleeve that needs to be push back, install the bolt and hammer it gently to push it out (the way of the green arrow...)
Install the alternator and torque the M8 bolt to 15 ft lb and M10 bolt to 38 ft lb” Thats what the spec reads, I just tighten them snugly. Plug the wire back on and be careful with the charging lead, I shock myself.
Install the pulley on and tighten the down the 4 bolts as much as possible. Install the belt by lowering the tensioner and routing the belt on, this took me a while with only myself. It helps to get another person to assist with the new belt. Now that the belt is on correctly, torque the four pulley bolts to 19 ft lb. I snug them because I didn’t have enough room for a torque wrench.
Tighten the radiator drain plug and fill the cooling system with fresh coolant. I was cheap and I filter the old red Toyota coolant with a coffee filter and pour it back in. (some of you might chew on me for that) Top it off with distilled water.
Install the splash shield and wheel. Torque the lug nuts to 80 ft lb. Remove the jack stand then lower the vehicle.
Start the vehicle and let it warm up, check for leaks. Then drive and keep an eye on the temperature gauge, listen for any strange noise, or weird driving characteristics. When everything is good and normal, give your Camry a good wash and wax. Stand back and admire your work for the day. (I still prefer my Gen 4.5 in the background)
Finally, clean the mess in the garage…
With the engine is cold, check the coolant level for the next few days, top off if neccessary. Hope this helps.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Last edited by Yuko; 05-11-2011 at 09:20 AM. Reason: Grammar and Spelling Overhaul
Yuko is offline   Reply With Quote
The Following 2 Users Say Thank You to Yuko For This Useful Post:
Sergomel (02-26-2012), workerant (06-11-2011)
Old 07-13-2010, 05:39 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Nice job.
gdanaher is offline   Reply With Quote
Old 07-14-2010, 01:47 AM   #3 (permalink)
iconman's Avatar
View iconman's Photo Gallery
Thanks but look too complicated.
iconman is online now   Reply With Quote
Old 07-14-2010, 03:17 AM   #4 (permalink)
View sykou's Photo Gallery
sticky maybe? of course after some grammatical corrections... NO offense meant...
sykou is offline   Reply With Quote
Old 07-14-2010, 05:53 PM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
6hrs.. wow. Awesomely done.
I'm curious if any1 tried doing this on a V6 Gen 6. I was told it's hell.
workerant is online now   Reply With Quote
Old 08-03-2010, 12:53 AM   #6 (permalink)
Yuko's Avatar
Weird that this DIY is dead
Old 08-03-2010, 12:59 AM   #7 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
I think a lot of people are afraid to tackle a project of this scope. Or it could have just slipped through the cracks, I had not seen this thread until now.
71Corolla is offline   Reply With Quote
Old 10-15-2010, 10:06 AM   #8 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Hmm... It looks as complicated as replacing timing belt on previous 4 cyl engine (5SFE; well, as tb on 1MZ too!)....
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 10-15-2010, 04:20 PM   #9 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5
you are the master champion professor magna summa cum laude of the Camry sir. excellent DIY.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 07-01-2011, 09:25 AM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
U participated in the ford/aaa competition as well? I just came in second place in the state of NJ.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 07-01-2011, 09:32 AM   #11 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
Very nice write-up!! It should DEFINITELY be made a DIY sticky.. I know theres also a compression test write-up on the Scion tC forums, and probably a few more helpful notes we could add as well...
I'm at 180k now, Japan built I4, haven't replaced the water pump yet, but seriously thinking about doing it just for insurance...
BlackG5 is offline   Reply With Quote
Old 07-01-2011, 10:57 AM   #12 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3627950
It was included in the DIY sticky when I reorganized and updated it a year or so ago. Check under the sub-section Engine Maintenance, Modification & Repair.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 07-02-2011, 01:58 PM   #13 (permalink)
View t3gtman's Photo Gallery
Very good write up! now I know what to do in the future when the wife's water pump go's out. Also a little info that might be helpful,instead of RTV sealant ,I use a product called Honda Bond,Toyota probably has a similar product ,but the Honda Bond stay's soft while also creating a seal,won't break off like RTV.
t3gtman is offline   Reply With Quote
Old 07-22-2011, 01:42 AM   #14 (permalink)
Yuko's Avatar
My partner and I came in third place in TX working on a little Ford Focus. Lost to first only because we forget to put the little red cover over one of the battery terminal and we wrote "green" instead of "grey" on other work order. But it was still fun.
Also, Thanks again mods for sticky-ing this.
